Question about Kohler Plumbing
Our Kohler shower/Tub faucet the water doesn't get very hot. It has a tempeture safety on it and it says to see instructions on how to adjust. We don't have the instructions as we did not originally install the faucet. It came with the house. How do you adjust?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
Koehler has great customer service. Free parts off needed and a patient staff on the phone. Look for their 800 number on Google.
Posted on Jan 19, 2016
  • 4,336 Answers
Usually you remove the lever and then you can see a gear like limiting ring. Adjust it one way or the other and test....
Posted on Mar 14, 2011
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Aug 27, 2009 | Kohler Home
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Plumbing Logo
267 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
