If it doesn't come out buy pulling on it, you probably have what is called a screw down crown. It is necessary to unscrew the crown before it will pull out. This is a feature found on diver style and other watches. It helps prevent water from getting in your watch. Once you set your watch, press on the crown and turn at the same time to screw it back down against the case. Snug is tight enough!
