Question about HP Pavilion s3020n (882780985063) PC Desktop
Trying to system restore to factory settings but f11 on the s3020n is not working.
  • Vern Haynes
    Vern Haynes Mar 14, 2011
    have you run a disk diagnostic? It sounds like you may have a hard drive problem. If not, I would run a drive diagnostic, either the HP diagnostic, or a bootable system disc that has a diagnostic.
    Did your PC come with (or did you make) system recovery CD/DVD discs? If the drive is bad you will need this to reinstall windows on a new hard drive.
    Problem Solver:
  • 14 Answers
Try using F1. Either hold it down as soon as you turn on the computer until you see it entering setup.
Posted on Mar 14, 2011
Dell Dimension 5150, formated main partition, and want factory settings restore
once you put in a different OS there is no factory system to restore . messed up on this one
Jan 30, 2018 | Dell Dimension 5150 Intel Pentium 4 w/HT...
ASUS Eee PC 1005HA-PU1X-BK Netbook how do fix black screen issue?It has an upper left corner blinking dash_
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jun 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I cannot start my packard bell..it hangs up into color blue when i launched start fix or start normally
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive may roll back to that date.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore
Hope this helps.
Jan 03, 2011 | Packard Bell Computers & Internet
After start up my computer goes to a black screen anyone know what i can do?
Hello
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
Hope this helps.
Oct 23, 2010 | Computers & Internet
I am trying to restore my Dell Inspiron 6400 to factory settings as I have a Trojan that I cannot get rid of. However when I press ctrl f11 nothing happens and my laptop continues to boot to the OS. I have...
If you want to reformat to factory condition, then press Ctrl + F11 at start-up when the blue bar comes up with "Dell.com" on it. If you miss it then just let it start up, then restart and try again. If it still does not work, press F12 at startup and select recovery option. Please note, if you have deleted the Dell Recovery Partition this will not work for you. You will need to reformat by inserting your Operating System CD at Startup and booting from that (F12).
Jan 13, 2010 | Dell Inspiron 6400 Notebook
My Sony Vaio PCG-K25 wont gp pass the black screen. I hear the fan and the power is on but the screen remains black. I took the battery out and had it powered through the chord. Still now working. Please...
Hello.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
Hope this helps.
Dec 08, 2009 | Sony VAIO PCG-K25 Notebook
Tough infection keeps returning
Hello.
If the malware is reinfecting your system, you really only have 3 choices: System Restore, Factory Restore or reinstall.
For System Restore, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Dec 04, 2009 | Microsoft Computers & Internet
Medion laptop restoration
May be you should try Ctrl+F11 or F11 as soon as you turn on the laptop. This would take you to the complete factory restore of the system
Aug 29, 2009 | Medion MD-40954 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Need to restore my laptop back to factroy setting
hi,
If you have a dell computer, you can restore your computer back to factory settings using CTRL+F11. You need to restart the computer and when you see the Dell logo. Press CTRL+F11. You will see the message "PC RESTORE"
You may reinstall your operating system using the cd if your system doesn't have the capability to restore settings to factory. You may call you computer manufacturer about it.
Keep me posted.
Thanks.
Oct 26, 2008 | Computers & Internet
HP Pavilion s3020n (882780985063) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
