Question about Philips 52PFL3603D/27 52 in. LCD HDTV
USER SETTING MENU WONT GO FROM THE SCREEN. WE WON'T BE ABLE TO SEE ANY OTHER PICTURE. WE CAN GET THE SOUND BUT NOTHING ELSE.
50pj350r
Try the remote menu leading to picture adjustments.
If nothing comes on the screen then you have a Serious failure on the board. No user fix, back to the dealer I am afraid.
Mar 09, 2014 | Zenith Z50PX2D 50 in. Plasma HDTV
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
We won an element 26in hdtv this weekend. we are
It could be a feature as some TV's have a zoom feature, widescreen setting, picture-in-a-picture, etc. Have you consulted the user manual?
Oct 19, 2009 | Televison & Video
I have a 46" (model 46H84) with wavy vertical lines throughout the screen. How can i FIX this myself? Is it possible? I've pushed the touch focus button and nothing. There is a 'convergence' option in the...
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 13, 2009 | Toshiba 46H84 46" Rear Projection...
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
My Canon Powershot SD630
Dear Peter,
It sounds to me as though your camera is experiencing the early stages of a CCD sensor problem. Users will often experience color changes and/or lines in their LCD screens when viewed in picture taking modes at this stage of the problem. Later on their sensors will ultimately fail completely and they will typicallt get nothing but a black screen.
To differentiate between a sensor problem and a LCD screen problem, try viewing your LCD screen in several different shooting modes (e.g. automatic, manual, program AE, etc) and then view your screen while in your menu (by depressing the menu button in any shooting mode). If you can clearly see your menu (OR, while in playback, pictures that were taken before the issue began) then it is your CCD image sensor and not your LCD screen.
If, however, all of these modes gives you the same distortion, it is your LCD screen itself that has experienced a problem. In either case, however, the primary solution is to send the camera in for service.
If you are under your 1 Year warranty this is usually no problem. If you are out of your warranty period and (and this is a BIG and) are capable of repairing your digital camera yourself, you have the alternate option of ordering just the defective part and installing it yourself. Replacment parts, however, come with no technical support and no instructions so make absolutely sure you are capable of repairing the camera should you choose this lower cost repair option. Hope this helps.
Sincerely,
HeavyDLB
May 13, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
No picture, have sound
Dude, you dont have the same problem thanks for junking up my post.
Ok, so I have replaced the SUB power assembly and the SUB Defconvergence board, picture looks decent however magic focus just blanks the screen out and cannot adjust manually does the same thing.
Is there a way to enter the service menu and initialize the magic focus functions after servicing.
It must be using the saved ROM settings, but it wont let me adjust anything convergence wise.
Thanks,
Joe
Dec 28, 2007 | Hitachi 46F500 46" Rear Projection...
Philips 52PFL3603D/27 52 in. LCD HDTV Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
