Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
How do i run the self clean cycle? - Kenmore 33464 / 33465 / 33469 Gas Single Oven
  • Kenmore Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Posted on Mar 14, 2011
How to set oven to clean
hi Sue.
this is all i could find on the internet.or go to the link at the bottom.
Before starting the Self-Clean cycle:
  1. Remove the racks, unless they are labeled as "self-clean". ...
  2. Any excessive amount of spillover (juices or liquid grease) not baked-on should be wiped out with a wet cloth before running through a self-clean cycle.
More items...
Range - Tips for Self Clean - Products - GE Appliances
How to set oven to clean Google Search
Oct 31, 2017 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Do you know how to test the fans on a GE Double Wall Oven (Model # JKP45W0P2WG) to see if they are working? I am wanting to make sure they are working prior to running a self-cleaning cycle. Thanks!
    Some models the cooling fans come on when you start the oven. In some models the cooling fans comes on only when the control compartment reaches a certain temperature. In this case there is a reverse thermostat. It will close for the fan circuit when it reaches the temperature thus starting the cooling fan.
    Dec 05, 2014 | GE Ovens
    I have neff double oven ,only had it two weeks and the top oven which i use the most looks filthy- i have had it on self clean at least three times but the floor of oven is burnt on and looks awful. W
    Self-cleaning ovens are not "squeaky clean" after the cleaning cycle has run. Any spilled food or debris in the oven before it cleans will be left behind as ashes, soot, etc. and you will need to wipe it out with a damp cloth afterwards. If the residue is black and sticky then the cleaning cycle isn't running at a high enough temperature. Please refer to the manufacturer's instructions to make sure the cleaning feature is working and being operated properly.
    Nov 20, 2014 | Neff Ovens
    Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
    Good Afternoon Friend,
    I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
      1) Place the rack holders and the racks in your oven.
      2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
      3) Restore power.
      4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
      5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
      6) Take the racks and rack holders out and start the self-clean cycle again.
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
      -Best Regards-
      WP
    May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
    How do i operate the self cleaning function
    Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
    Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
    When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
    If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
    Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
    I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
    Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
    Here is the manual with "troubleshooting". Hopefully, it will help!
    Operation Bosch HES5053U 31 100
    Jun 29, 2017 | Bosch Ovens
    Locked after self clean cycle
    you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
    Jul 14, 2010 | GE JKP45 Electric Double Oven
    I would like to clean inside my oven on the top
    if you have a self clean oven, do not use an abrasive cleaner to clean
    I would recommend running a self clean cycle, and anything left
    "Mr. Clean Magic eraser" should take care of it.
    it works miracles in ovens
    May 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Whirlpool RF367LXS Ceramic Glass Range not working
    Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
    Feb 02, 2008 | Ovens
    Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
    78 people viewed this question
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
