Question about Refrigerators
My toshiba refridgerator model GR41-ST is not cold enough. foodstuff store in freezer compartment not freezing up. temperature level has been set to maximum coldness
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 14, 2011
Freezer and refrigerator are not keeping cold
the thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Seems to be constantly running. refridgerator section too cold, with items freezing.
it could be 1 of 3 things,1st: the ptc overload on the compressor has welded together and cant cycle on and off/2nd:the cold control is defective,this component is the part you set the units temperature with/3rd:your damper vent door located between the freezer and refrigerator compartments could have frozen open from condensation and cant close to keep the cold out of the refrigerator after the refrige is cool enough,this is behind a plastic grille in the refrigerator and brings in cool air from the freezer
Dec 11, 2010 | Maytag Refrigerators
I have a Crosley refrigerator that is about a year old. We decided to replace it because it wasn't big enough. We moved it to our garage and since we've moved it, it doesn't seem to be chilling the...
If the garage is unheated and the garage temperature is below 50 deg F this is the reason that the freezer is not able to freeze. A refrigerator is designed to work in a heated space. The thermostat is in the refrigerator compartment while the cold evap coils are in the freezer compartment. The fridge thermostat is typically set to around 40 deg F. When the fridge is in a colder environment, the compressor does not need to work that hard to get the refrigerator to temperature. But the freezer on the other hand, will be above freezing.
To fix this, there are garage refrigerator heater kits available, for just this situation. They are placed in the refridgerator compartment to heat the thermostat. This causes the compressor to run longer, and thus maintain the freezer temperature better. You could get one of these heaters or you could put an light bulb in the refrigerator to do the same thing as the heater. Remember to use a regular light bulb, and not a cfl or led light bulb, they won't generate enough heat. Also remove the light bulb or heater in the warm months unless you want a higher energy bill. Hope this helps you.
Dec 09, 2010 | Crosley CFFH10W Top Freezer Refrigerator
I don't have a problem but I would like to know how to set my Dandy refridgerator.Its an upright small fridge.the knob only I see is in the fridge part.I don't know how to set the freeser part .There is...
Compact refrigerators that have a freezer compartment do not have seperate controls since they are cooled by the same evaporator and it is not designed to reach true freezer temperatures. It should get cold enough to freeze water for ice. If it were allowed to get much colder there would be problems preventing the refrigerated section from getting too cold. Therefore, you will have to find a setting that provides a good compromize. You should be able to keep frozen dinners and such cold enough to prevent them from thawing but I would not store meats too long in that freezer and ice cream will get soft. I hope this answers your question. - Subdriver
Feb 03, 2010 | Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
