Question about Vacuums
We need a threading diagram for a JUKI MO 2300 SERIES INDUSTRIAL OVERLOCKER
2 Suggested Answers
  • 586 Answers
SOURCE: I have a acquried a
Hello there,
Theres a number of causes of such problems. You will simply just have to run a check on some of the components below:
If it is the upper thread that is breaking, check Rethread your machine. An incorrectly threaded machine can cause thread to break.
Decrease the tension on your machine. The tension may be too tight for your thread.
Reposition the spool of thread on the spindle. You know that little nick in the edge of a spool that's used to hold the loose end of the thread? Your thread may be catching on this nick as you sew. Place your spool so that this nick rests against the bottom of the spindle.
Reinsert your needle. Make sure it goes all the way into the holder and that it's positioned correctly, usually with the flat side away from the bobbin, but consult your machine's manual to be sure.
Change your needle. Your needle may be bent or dull. The eye of your needle may have a nick in it that's cutting the thread as you sew. Or the eye of your needle may be too small for your thread, in which case, change to a larger needle. And make sure your needle is appropriate for the weight and type of your fabric.
Change your thread. Your thread may be weak. Or your thread may be fuzzy and irregular, causing it to catch in the eye of your needle as you sew. Cheap thread tends to be weak and fuzzy, so make sure to use a quality, brand name thread. And if you've been sewing with an older cotton thread, which can dry out and become brittle with age, try a newer thread.
Check your presser foot for damage to the needle hole.A burr in your presser foot's needle hole may be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Also, There may be a burr in one of your thread guides, in which case, you may need to have your machine professionally serviced to have the part replaced.
If your lower thread is breaking: Reinsert your bobbin. Your bobbin may not be seated properly in its case.
Rethread your bobbin. Your bobbin may be threaded incorrectly or the thread may be tangled.
Remove some of the thread from your bobbin. If your bobbin is very full (if it's hard to insert into the case, it's too full), this may be keeping your bobbin from turning smoothly.
Rewind your bobbin thread. If your bobbin thread is wound unevenly, this may be keeping your bobbin from turning smoothly.
Try a new bobbin. There could be a nick along the edge of your bobbin spool that's catching your thread as you sew.
Clean the lint from your bobbin case.Lint in your bobbin case could be keeping your bobbin from working properly.
Check the needle hole in your throat plate for rough spots. A burr in the needle hole of your throat plate (usually caused by the needle hitting the throat plate) could be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Hope this helped. Goodluck Elect_Comp
Posted on Aug 31, 2011
I CANT THREAD MY 1034D BROTHER OVERLOCKER
If you cannot do this due to not knowing how, here is your manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
If you are looking for specific information on how to thread a specific looper or needle:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&
prod=hf_1034deus&Cat=53
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | Vacuums
I need a user guide for a Commercial Brother sewing machine model DB2-B716-403AB, I need to see how to thread it, and I need to see how the bobbin works(bobbin thread is not picked up by the neddle. And I...
i went on line on how to thread an industrial machine and the the bobbin is the opposite of a regular machine. when handleing the bobbin have it so the thread is going down the right side so it looks like a number nine.hope this helps
Jun 02, 2011 | Vacuums
Where can I get a free manual for a Tokyo Juki Industrial Sewing Machine # DDL-227?
Not sure if this is the complete manual but only site where I could find it available for free:
http://www.free-service-manuals.com/Sewing_Machines/Juki_DDL_227_Basic_Repairs_&_Adjustments_L98742/
Click on Download/Visit to receive the manual in zip format.
Mar 27, 2011 | Vacuums
My overlocker is jammed with the needles in the down position - I have not used it for a while and hve just oiled and cleaned it.
Oh man.
Not sure how to get it unjammed but I know that if overlockers/sergers aren't threaded properly they can jam up like that. The last time that happened to me... broken looper.
Open up the front and start clipping threads... Gently rock the hand wheel to see if it loosens as you get thread released.
Honestly I suspect that your machine has locked up because it's been knocked out of time. If you still have problems take it in and have it serviced.
Mar 12, 2011 | Vacuums
What bobbin do I use in a Juki DDL 8300
Hi there.
Nice machine... Here is a link to all the parts for your Juki DDL 8300
http://www.juki.co.jp/industrial_e/webparts_e/partslist2.html
Your bobbin's Juki part number is B9117-051-000
Mar 11, 2011 | Vacuums
Trying to get the instruction manual for a Janome Overlocker MY/LOCK 204D
Hi
You can get partial manuals from the Janome site.
http://content.janome.com/documents/File/ManualFile/MyLock204D.pdf
It should help with the basics of threading your machine and getting started.
Nov 21, 2010 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
262 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
