Just wanted to know where the lint filter is located. how do I access to it, and how often should I change the filter.
  • 4,348 Answers
It is extremely difficlut to actually answer accurately, without a MAKE and MODEL of your machine....
BUT, if there is no lint filter in the tub area, you may have an automatic cleaning screen. The way it works is that water travels in one direction, and the screel collects lint, then on drain, the water direction reverses and that cleans the filter. This design is essentially maintenance free.
Posted on Mar 14, 2011
I want to clean out lint filter of my fisher paykel washing machine but i do not know how to dissasemble the machine to get to iy
Search in Google how to change lint filter in fisher washing machine and click on images link
see and follow the photos
Dec 13, 2013 | Washing Machines
Where is the filter?
Generally for front loaders. Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side (screws underneath?) and find access at the right hand side. Keep a large flat container ready to collect water from drain filter. You clean out the filter, don't change. Whenever you think it is clogged.
If helped pl click so.
Mar 23, 2013 | Haier RWT350AW Washer
Dryer won't start, replaced start button
The push-to-start button is not, in most cases, the culprit. There is a thermal fuse on the blower housing and wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Feb 10, 2011 | Kenmore Dryers
Dryer makes click when push start button but wont start
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Feb 01, 2011 | Kenmore Dryers
My dryer will not start. when i press the start button, the sensor light comes on and the dryer will not start.
This problem is usually due to a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Jan 27, 2011 | Whirlpool Dryers
Lights turn on but dryer wont start
The problem is likely a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Jan 23, 2011 | Kenmore Dryers
Will not start
The problem is likely a blown thermal fuse.Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dec 18, 2010 | Whirlpool LER5636P Electric Dryer
Thermal fuse location on a 110.9597590110 gas dryer
The model number of your machine doesn't seem to exist but the thermal fuse, whether dryer is electric or gas, is always located on the blower housing together with the thermistor or cycling thermostat depending on the model of the dryer. The blower housing is located at the rear of the dryer if the lint filter of you dryer is located on top of the cabinet and can be accessed by removing the rear panel.
The blower housing is located on the front right bottom of the dryer if the lint filter is located on the door. It can be accessed by removing the kick panel.
Kick Panel Removal
Once the kick panel is removed, remove the lint chute to expose the blower housing and the thermal fuse.
Sep 30, 2010 | Kenmore Dryers
I have a Bosch Vision 300/500/dlx and it cant get rid of the water, It had a message E 13, and i have cleaned the drain hose, I want to clean the Filter but I dont know where it is. when running the rinse...
I don't know your model, but the filter will be accessible without getting into the innards of the machine.
Look for something that looks like it might turn to unlock, then pull out located low down at the front or the back of the machine.
On my top loader the filter is housed in the spindle of the agitator post. Pulls out and reveals lint bag etc.
Dec 30, 2017 | Bosch Nexxt 300 Series WFMC2201UC
Want to remove the lint basket that the filter
your best bet is to remove the front panel of the dryer and pull the front drum/blower duct assembly off the machine. You can then fully access all areas of the duct and also clean all the lint build up inside your dryer.
Nov 27, 2009 | Cars & Trucks
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
