Question about Goldstar Microwave Ovens
We have a Goldstar GMS 1124TW and it has stopped heating, everthing else works.
  • Goldstar Master
  • 3,051 Answers
Hello there
Whenever you have a no heat situation in your microwave this is due to the megnetron being faulty and needing replacement
i will give you the full procedure to test and replace if needed
The following resistance tests will conclusively reveal a magnetron that is shorted or one that has an open filament winding.
test 1
1. unplug the oven make sure the oven is completely disconnected from any power source
2. discharge all power from the capacitors.
3. Carefully remove all leads from the magnetron terminals. Proper wiring is important so make notes of the wire locations.
4. Set the ohmmeter to its lowest resistance scale.
5. Measure the resistance from one magnetron terminal to the other in either direction.
6. The magnetron filament resistance should be less than one ohm. If this test fails read my next post on replacement
Test 2
1. With the meter set to the highest resistance scale, check from the magnetron terminals to the metal magnetron housing. (Be careful not to touch the meter leads as this will result in a false reading).
2. The meter should read infinity (open circuit) regardless of meter polarity.
3. Even a slight reading would indicate a defective magnetron.
replace the old
remove the wire that attach to the magnetron and mark to identify where they go
unscrew the screws that hold it in place and remove
1. Be careful not to strike or touch the antenna dome area
2. Be sure to transfer any add-on parts, such as an air duct or thermal fuse
3. Insure that the wire mesh rf gasket is intact and in place
4. Examine the rim of the opening where the magnetron dome is to be inserted into the waveguide. smooth out any irregularities, such as dents, pits, and burns. the rim surface should be bare metal, smooth to the touch. use light-grade sandpaper do not use steel wool.
5. If there is evidence of poor terminal connections i.e., discolored, burned, pitted connectors), repair or replace the slip-on connectors on the filament leads
6. install the new one and replace the screws and wires and marked then plug in the microwave and test
Posted on Mar 14, 2011
  • Michael Thomas
    Michael Thomas Mar 14, 2011
    Sorry i forgot to add a picture of what this looks like here it is there are 2 different ones for your unit $59.00a piece
What would cause my Goldstar microwave to stop heating and the tray to stop revolving?
if timer and all other controls seem to work correctly id say a loss of high voltage section in microwave power generation part there can be several reasons for this a profesional serviceman can find more about why ?
Sep 09, 2014 | Microwave Ovens
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Goldstar MV1501BQ no heat
Hi LMGreen! Sorry for the late response a bit busy at work.. Coming back to the problem..
Solder joints on power control board are cracked and/or burned. Inspect solder connections on power control board for deterioration. This usually occurs where the harness connector is mounted to the circuit board. Reinforce and re-solder as necessary. Also check all other solder joints.
Apr 19, 2008 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
