Question about OKI Electric Industry ML320 Matrix Printer
Esp on after start cheked the code was c1170 steering angle sensor my car c230 2004
2006 JEEP GRAND CHEROKEE ESP BAS WARNING LIGHT ON
The BAS/ESP lights pertain to your brake assist and electronic stability systems. One of the more common problems we find is a faulty stop light switch or a steering angle sensor. It would be a good idea to have the fault codes read. The codes would give you a pretty good idea as to what is going on. You could try to initialize the steering angle sensor first. This is normally needed after a dead or weak battery condition. To do this you'll need to start the car and then turn the wheel slowly all the way to the left, pause and then turn slowly all the way to the right, pause and return to center. You may need to do it a couple of times to initialize the sensor. The stop light switches are inexpensive ($20.00) and easily replaced. They're located under the dash at the brake pedal. When you get your new switch you'll see a little release tab on it. You just depress the tab and rotate the switch 90° to remove it. Of course you may have other problems. Reading the fault codes would be the best place to start. Good luck
May 26, 2017 | Jeep Cars & Trucks
ERROR CODES C 1140 AND C 1202
1140 is for the **** spring/ steering angle sensor. In the steering column. 1202 is the brake pedal switch. I would check fuses first. Your owners manual will tell you which ones.
Aug 21, 2016 | Mercedes-Benz C-Class Cars & Trucks
My slk 280 says take to shop for esp on the dash. why?
Because you have a fault code & dash light on
The ABS System may have a problem
Google what ESP is about
No --you can not get it off your dash
You can & it will come back, until you
make the repairs
Sep 27, 2014 | 2007 Mercedes-Benz SLK 200
Loss of power
Pull up the diagnostic error codes with the help of diagnostic computer and repair as necessary.
Both the ASR (Anti Slip Regulation) and ESP are concerned with the brake system. ESP is the latest one which includes in it ASR, BAS, ABS and ETS in a single control module. It uses steering angle sensor, Yaw rate sensor, acceleration sensor and all wheel sensors to decide which wheel to brake.
In short, delete the error codes and calibrate the sensors.
Feb 27, 2014 | 2010 Mercedes-Benz Sprinter
ASB,ESP INOPRATIVE
All you have to do after replacing the battery and the bas/esp light comes on is drive the vehicle. While your driving around is will allow the steering angle sensor to relearn. That's only if it says "bas/esp see owners manual" displayed on the cluster.
Sep 20, 2012 | 2007 Mercedes-Benz C-Class
Esp warning light and bas on
Hi there:
The BAS/ESP lights pertain to your brake assist and electronic stability systems. One of the more common problems we find is a faulty stop light switch or a steering angle sensor. It would be a good idea to have the fault codes read. The codes would give you a pretty good idea as to what is going on. You could try to initialize the steering angle sensor first. This is normally needed after a dead or weak battery condition. To do this you'll need to start the car and then turn the wheel slowly all the way to the left, pause and then turn slowly all the way to the right, pause and return to center. You may need to do it a couple of times to initialize the sensor. The stop light switches are inexpensive and easily replaced. They're located under the dash at the brake pedal. When you get your new switch you'll see a little release tab on it. You just depress the tab and rotate the switch 90 degrees to remove it.
Before to replace some parts, I suggest scaned the computer car in order to know other fault codes stored.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Jul 06, 2012 | Cars & Trucks
I have mercedes benz E220 cdi avantgrade,i havent been driving my car about one week.this morning when i start engine cardidnt start, on dash board tis apeared ,ESP not avallabel see owners
The ESP message came on because the battery went low causing your steering angle sensor to lose syncronization. There are 2 different ways to resync the steering angle sensor. One way is turning the steering wheel from lock to lock and the 2nd way generally involves just driving the car around like normal and it will resync on its own. You will most likely just have to drive the car around until it resyncs on its own because of warning message your getting. When it says see owners its because in the owners manual there is a description on what the message means and what to do to fix it. Basically it just tells you to drive the car. Hope this helped you out.
Feb 20, 2012 | Mercedes-Benz E320 Cars & Trucks
Esp light is on. came on after I removed fuses trying to solve rear spoier problem which i think is now ok. pasted mot yesterday, garage said no problem with esp itself
ESP will communicate with steering angle sensor. You have pulled the fuse for the ESP system so it has lost it's base settings. It will clear once it has re-learnt. Try turning ignition on then steer full lock to full lock to give the system chance to relearn steering angle parametres
Feb 19, 2012 | 2004 Chrysler Crossfire
Recode steering angle sensor
For recode the steering angle sensor you must connect a diagnosis scantool to the data link connector of the car in order to access the ESP ECU (Electronic Control Unit), in other words programm again the steering angle sensor in the ESP ECU. Select the steering angle sensor programming (learning) menu, and follow the steps: put steering wheel in straight direction, then turn steering wheel to the left direction less 15 degrees, then to the right direction less 15 degrees, put steering wheel in straight direction again until the programming was done. Then the ESP light will turns OFF.
Aug 20, 2010 | Audi A6 Cars & Trucks
On my passat ESP warning is coming on. i have changed yaw rate sensor allready and ESP warning light is still coming on. what should i do? its Passat tdi 130, 2004. Thanx
You should have the OBD codes checked. This will determine the exact fault. The ESP light will sometimes come on if there is a problem with the ABS or with the steering angle sensor.
Good luck with this
John
Oct 27, 2009 | 2004 Volkswagen Passat
OKI Electric Industry ML320 Matrix Printer Logo
172 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
