Question about Panasonic KX-T7630 Corded Phone
How do we set up the phone system so that an outside caller can call our extension directly without having to go through reception/main unit?
  • Panasonic Master
  • 2,460 Answers
There are a couple of ways. The easiest one is to use the Panasonic voice mail system which has an auto attendant built-in. It can be programmed to answer incoming calls, play a menu and let the caller dial extensions or ring the operator. If no one answers, it can take messages and provide the voice mail for the system. The TVA system has a LAN card that can send voice mail to email. It's optional in the TVA-50 and included in the 200.
Carl
Posted on Mar 14, 2011
New extension num. (for Transfer) using other line
WHAT TYPE OF PHONE SYSTEM IS THIS YOU ARE USING? USUALY YOU PRESS THE A SWITCH HOOK FOR A SECOND DIAL TONE DIAL THE XTENSION ,WHEN IT STARTS TO RING YOU MAY PRESS TRANSFER ,OR WAIT FOR THE PERSON YOU ARE TRANSFERING TO ANSWER THAN ANNOUNCE THE CALLER THAT HANG UP. IF THERE IS A PBX INVOLVED YOU MAY USE A INTERFACE TO PROGRAM THE SECOND LINE ON YOUR TELEPHONE. HAVE THE I T PERSON CLEAR THE CASH.
Jan 14, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
My answering machine won't pick up to external callers
Try Googling (Panasonic)(KX-T7456)(manual) without parens to get instructions.
Jun 05, 2017 | Panasonic KX-T7456 Corded Phone
How do I change the current extension on my polycom 301 phone from 334 to 300?
Go to support on the new phones manufacturers web site and you can download an owners manual, which will tell you how to re-program the phones extension. murf427
Aug 01, 2012 | Polycom IP 301 SIP IP Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How to transfer a call to voice mail from reception phone
press feature 986 and the extension number. The caller will be transfered directly to the extensions mailbox.
Dec 02, 2010 | NorStar M7310 Corded Phone
Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
I am trying to get into the main outgoing message (the one that comes on as soon as an outside caller dials our number---which directs people to the various extensions). I need to change that message and I...
You need to dial the vociemail system, when prompted, enter the admin mailbox followed by #
That is the admin mailbox and password for a Partner voice messaging.
Make sure thats what you have....
Sep 02, 2008 | Avaya Lands Phones
Panasonic KX-T7630 Corded Phone Logo
168 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
