Done outside gummy inside - Computers & Internet
  • 592 Answers
Hi.
I'm guessing that this is a cooking problem, so here goes.
If the food your cooking is done on the outside, but not done on the inside, then you have the temperature at the wrong settings.
Reduce to a lower temp, try with a new batch, and cook it for 50% longer at the lower temp: i.e. if it said 350 degrees for 30 minutes, then reduce to 300 and cook it for 45 minutes instead.
The longer time allows for the heat to penetrate and cook the middle, not just the outside.
I hope this helps you out, and good luck.
Posted on Mar 14, 2011
How can i remove rear door card from xtrail when door will not open from inside or outside Regards Barry
There should be a way to get it open from the inside , have done this on other vehicles, keep looking , there has to be a way to open when the electric lock unlock switch fails...
Nov 04, 2016 | Nissan XTrail Cars & Trucks
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
1986 nissan 300zx passenger door wont open from inside ,can from outside
Remove the inside door handle cover , Take out the piece that has yhe rods attached to it . There is 2 black plastic pieces that one opens the door and the other one locks the door. One is broken . The one that opens the door from inside, Reolace the piece and put the rods back on. put cover on . Done.
May 07, 2012 | 1986 Nissan 300ZX
Transs. slips after oil change
Some times on higher mileage cars your transmission will slip when you have the transmission serviced or flushed. The reason for this is that transmission fluid has detergents in it that help clean your transmission. When transmission fluid ages it losses most of its detergent which causes your transmission to become a little gummy inside. This gummy residue helps your transmissions bands and clutches to stick. Now since you have new fluid and new detergent in it it has cleaned away this gummy residue causing your transmission to slip. There is a simple solution for this problem. All you have to do is make your bands and clutches sticky again. Simply go to your local parts store and get a bottle of Lucas transmission treatment. Within a few day you should notice the slip decrease and totally disappear within 100 miles or so. I hope this helps you out. If you have any more questions please feel free to ask.
Sep 16, 2011 | 1986 Lincoln Town Car
I have a danby portable air conditioner with no manual. The picture shows two ducts going outside. My question is why does the intake go outside?
On a portable a/c unit the cooling is done by taking heat out of the air inside and dispensing it outside.
That's accomplished by washing air over the heat coil in the unit, then the air goes back outside to let the heat out there.
You'll need inlet air, and outlet air to accomplish that.
Inlet air is cooler as it comes in, then that air absorbs some of the heat inside the space you're cooling and turns around to go back out leaching heat outside.
Most likely scenario.
There may be another need for outside air revolving around positive pressure inside the conditioned space.
Let me know if that doesn't solve your situ.
Russini
Oct 30, 2010 | Danby Heating & Cooling
How do i remove my front light cover to clean the inside
The front cover is mounted in a way that you cannot remove it. If you are trying to clear the yellow, polish the outside with an appropriate polish. The damage is usually done to the outside. Ifnyou have done this and it is still yellow, then you need to replace the lights.
Oct 16, 2010 | 1992 Lexus Es 300
How do i replace a fuel pump on a 2002 ford
It woild be better to just to buy a new pump, from your vehicle sitting for three years the gas inside the pump became gummy and has a build up of varnish.
it would be more time and cost effective to just buy new one and be done with it.
Apr 16, 2010 | 2002 Ford Explorer Sport
6th gear problem 03 tiburon
does the car have 100,000 miles? is the clutch pedal have a high release?the shift cables could be binding ,i've only replace 1 in 4yrs and that guy was drag racing the car..i don't know what gummy means, but you could also have a syncronizer worn out in sixth gear. did you look at the old gear oil for brass or metal?
Oct 28, 2009 | 2001 Hyundai Tiburon
Trans shifts hard into 6 and out other gears shift fine
having the same problem... my car is an 03 as well... any solution yet? i flushed my tranny, put in synthetic, made sure the linkages were lubricated inside and outside the car, and still nothing.. theres no grinding, at all, its just really gummy
Apr 04, 2009 | 2001 Hyundai Tiburon
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
