Question about Harman Kardon AVR 525 Receiver
Multi room speakers stopped working. Settings correct and verified; professional installer verified speakers and wiring is good. The receiver is working fine otherwise. Any suggestions?
  • johnstd98 Mar 14, 2011
    Just to verify-- we have connected zone 2 speakers to a different source to verify they are working and the wiring is fine. The connections at the source have been verified. Settings in the unit show the appropriate input but zone 2 doesn't work with any input (even FM radio) at the receiver. However, the receiver is not in protected mode and everything else is working properly so an internal short seems unlikely. I have powered down the AVR525 and reset the microprocessor but it does not resolve the problem.
    President:
  • 739 Answers
Hi..
If everything is in good condition, it is impossible for it failed to work unless there is something that causes failure.
try once again to check more carefully, especially the connections in and out of the speakers, there is a cause fail to produce sound.
Dengar Baca secara fonetik regards Kamus - Lihat kamus terperinci
  1. kata sendi
    1. if
    2. when
    3. in case
Posted on Mar 14, 2011
  • 415 Answers
One of those things that were tested is not right. You'll need to do a process of elimination. First try connecting one local speaker and see if you actually are getting output. If not then you know the problem is with the receiver or connector.
You can also hook up something else to your multi-speaker wiring and see if it works through that wiring and speakers, ie a tv or anything that can use the same kind of connector you're using.
If you get sound out from something else then again you know it's with the reciever, either a problem with the settings or the unit itself.
Obviously you can also double check the settings too and make sure they are right.
It has to be one of those things, a connector, wiring, a setting or the unit itself.
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
How to reset denon s 301receiver?
Instructions
  1. How to Reset Denon Receivers
    • 1 Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
    • 2 Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
    • 3 Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
    • 4 The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Sep 09, 2014 | Toshiba DVR40 Multi System DVD Recorder...
How to reset denon avr4800 thx receiver?
These are the following steps to reset your Denon receiver:
1. Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
2.Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
3.Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
4.The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Read more: How to Reset Denon Receivers ' eHow.com http://www.ehow.com/how_7441680_reset-denon-receivers.html#ixzz1wpEtIRTB
If the information helped you out please give some me some ratings. Thanks
Jun 04, 2012 | Denon Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Multi Room / Multi zone problems
As you may see from my posted response to a posting that correctly ID'd the solution, the answer to your problem is found on p. 47 of the manual (regarding how to adjust the multi volume levels as stated on p. 26).
Jun 20, 2008 | Denon AVR-3802 Receiver
Fade F to R not working on Sony CDXF7000
Hi, To my knowledge, this head unit (Sony CDXF7000) uses individual 52 watts amplifier (X 4) whose output to the speakers require that none of the speaker wires be grounded or crossed/shorted. Please check the speaker wiring with the use of an ohmmeter (or a multi tester) with all the speakers temporarily disconnected. Verify that none of the 8 wires reads 0 ohms to body/chassis ground or to any of the other wires. As you have checked the wires area: front left > + red & - white/black stripe; front right> + gray & - gray/black stripe; rear left > + green & - green/black stripe; rear right > + purple & - purple/black stripe. Rewire should it be necessary. If the wiring fully checks out, it may be that you have a fader component failure inside the unit (though honestly rare). You can also check if there is no bridging modifications done; converting your 4 amp-4 speakers original design to a bridged 4X52=2X100watt amp to 4 speakers paralleled to 2. Another area you can check/try is by varying the DSO settings - 1,2,3,off. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Car Audio & Video
Harman Kardon AVR 525 Receiver Logo
97 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
