Question about Husqvarna Garden
HI,I'M HAVING TROUBLE IN KEEPING THE ENGINE RUNNING AFTER START-UP,I PRESS BRAKE PEDAL TO START-OK,BUT WHEN I RELEASE THE PEDAL THE ENGINE CUTS OUT(WIRING ISSUE I THINK?)
  • 2 more comments
  • ice031 Mar 14, 2011
    HI,THE ENGINE KEEPS RUNNING AT ANY REVS FOR AS LONG AS I LIKE,BUT AS SOON AS I RELEASE THE BRAKE PEDAL-INSTANT ENGINE STOP,BY PRESSING THE PEDAL I'M ABLE TO START ENGINE-IF I DON'T PRESS PEDAL THERE IS NO POWER TO THE STARTER.
    THANKS FOR THAT INFO,I WILL CHECK THAT WIRE TO THE COIL AND WILL BE IN TOUCH SOON.
    HI, MAY I ALSO ASK YOU A CUTTING DECK QUESTION?,WILL ALSO ADVISE YOU ON THE ENGINE CUT-OUT PROBLEM REMEDY. THANKS
  • ice031 Mar 15, 2011
    HI, THANKS FOR YOUR HELP- I HAVE JUST REPLACED THE CUTTER DECK BELT (WITH TEETH ON IT),BUT NOW THE 2 BLADES HIT EACH OTHER WHEN I SWITCH IT ON,A FRIEND SAYS THAT IT SHOULD BE TIMED TOGETHER?,CAN YOU HELP WITH THIS?
  • 438 Answers
Why should you press the brake pedal at startup?
To keep the engine running you must give it a little more throttle. Since it does not get enough gas, it dies out. If it still does not behave then the clutch needs adjusting. You must tighten the clutch a little at a time. Till the engine starts staying on without help. Do not over tighten the clutch as it would keep slipping and burn ultimately.
Posted on Mar 14, 2011
  • Vinay Kumar Mar 14, 2011
    OK.
    In that case it seems that the power lead to the coil is shorting somewhere. Please check and replace it. When you press the brake pedal, the lead is lifted a little and the short is avoided and the moment you release the padal the wire again starts touching the body. Have someone else press the brake while you inspect the hood and below.
    Please.
After starting it runs only seconds then cuts off
Compustar monitors your vehicle's engine to validate remote start activity. In the event your engine cannot be detected, the remote start operation will be cancelled after (3) three unsuccessful attempts. Additionally, you could receive error 8, error 08, or even error 01 on your LCD remote when you have this issue.
Troubleshooting:
  1. Start your vehicle's engine with the key.
  2. Press and hold the foot brake down.
  3. While keeping your foot on the brake, press the KEY or remote start button button for 3 seconds.
  4. Release the foot brake and remove the key from the ignition.
If you continue to experience failed remote start attempts, please contact your original installer or authorised dealer for assistance with this issue.
Apr 03, 2016 | Vehicle Parts & Accessories
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
Car will not accelerate when gas pushed
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
My clutch won't engage 1997 Honda civic
Apr 06, 2013 | 1997 Honda Civic
I have a Lexus RX300 1999 model and have this recent problem. engine running normally but gear gets stuck in Parking mode and won't shift. had to depress the emergency button on the gear shift and
Some automatic vehicles rely on the brake switch (mounted on brake pedal) to be activated by depressing brake pedal. This signal then operates a relay and switch, to release the gear lever.
Firstly, I would check the brake pedal switch (are your brake lights working?).
If brake switch is confirmed OK, then inspect the relay (and related circuit components) of the gear release switch.
Mar 04, 2013 | 1999 Lexus RX 300
My 2001 Buick Regal will only start if press the gas pedal, when I release the gas pedal to step on the brake the engine shuts off. Any Ideas?
Could be a dirty throttle body or a faulty idle air control valve.
The computer controls idle speed by regulating the amount of air entering the intake thru the throttle body.
Jan 25, 2013 | 2001 Buick Regal
2007 gmc canyon sputters like it is going to cut off when applying brakes sometimes hard to start. just changed plugs and air filter . could it be brake booster or something else
if I say possible servo booster is faulty,surely you will feel it on the brake pedal ( stiff ),or the engine running would be erratic.the other alternative situation is the pipe( hose ) which is connected with inlet manifold and servo booster and inside has the check valve probably is faulty. Test : off engine,pump brake pedal several times till gets stiff. Keeping your foot on brake pedal start the engine and if your servo works fine then the pedal goes a bit down,if not will not move at all. If the engine is running erraticly then with engine off, remove the pipe connecting manifold and servo block the pipe you remove from servo side,block it and start the engine,If engine run fine,then you must confirm whether is the servo or the check valve hose. For the check valve hose how to check,just put in your mouth the servo side pipe and blow into,if the air goes in the engine means that the check valve is broken and you must renew the pipe with check valve,if on blowing into will not allow air to get through,means is ok and the servo is the fault. Good luck.
Jan 03, 2013 | 2007 GMC Canyon Crew
Start engine, step on brake, press release button, will not come out of park
try to turn key on first click of ignition. shifter release is controlled by shift actuator. check for blown fuse..
Dec 16, 2012 | 1995 Toyota Corolla
Replaced rear brake pads, now there is a hissing sound coming from brake pedal when i start it , come to complete stop and after i turn car off .what is the hissing or air pressure release sound coming...
There are 2 things that can use vacuum near the brake pedal. If you have cruise control, there is a safety switch on the pedal to shut off the curise when you apply the brake. This switch may be leaking.
The other part is the brake booster, which is actually in the engine compartment but bolts to the firewall, and your brake pedal mechanism pushes into the booster. You will need to get your head under the dash with the engine running and press on the pedal to locate the leak--on the switch or on the wall.
Sep 07, 2010 | 2004 Ford Expedition
Have to press hard on breaks to break on 528i bmw 2000
sounds like brake booster not working
check vacuum hose that goes to booster is ok and not leaking
engine off
pump up brake pedal several times
hold brake pedal down
start engine
pedal should sink down approx half to 3/4 way down indicating booster is working
if pedal doesnt go down when engine is running booster has leak or no vacuum supply from engine which requires great pedal effort to try and get vehicle to stop.
Jun 26, 2009 | 2000 BMW 5 Series
Garden Logo
91 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
