Question about GE JBP65 Electric Kitchen Range
GE Range JBP69 samller burner of the dual burner doesn't work...
I replaced the infinite switch. But that didn't fix the issue. What can I do next?
Thanks in advance
  • milicose Aug 08, 2008
    After lifting up the glass top and replacing the element here are my comments:
    if you have a problem of smaller element of the dual element not working then it ought to be your element that needs replacement.. Unfortunately you can not just replace the smaller or the larger that has gone bad but have to replace the entire combo-element... if your hotsurface indiactor light and the element-on indicator light are working and are able to turn the heat from high to low on the working element (either small or large) then definitely the problem is NOT WITH THE INFINITE SWITCH. If it is your larger element that is not working then it could be either your rocker-switch or the element that could have gone wrong... To isolate the problem directly join the two ends that are connected to the rocker-swich and see if your larger element works. If it does not work then it has got be a bad large element....
    If your problem is with any of the other non-dual element not working.. to isolate the issue swap the infinite swith with any of the other working ones (because they are identical) before buying either the element or the inf. switch..
    one more thing... be carefule with the element in case you are replacing that.. the non conductive heat resistant material that is enveloping the coil is so soft that a little extra pressure crumbles that... --- Good luck
  • tburkel1 Nov 27, 2008
    My small burner doesn't work but the big one that is together does work. I don't see how the cook top comes off to get to the burner to repair or replace the element. Is there a trick to taking off the top? Its a GE JBP69...
    tburkel1@cinci.rr.com
    Tom Burkel Thank you!
  • 93 Answers
These burners are not that difficult to get to, but you will have to get access to that burner or element to do testing. Screws hold the top down located just under the top front edge. Open oven door to see screws. Remove screws to lift up top. It will pivot on the back edge. You will see the elements. If you do not feel safe doing this get professional help.
Posted on Aug 01, 2008
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
GE JBP69
Replce infinite switch.
Jul 18, 2008 | GE JBP69 Electric Kitchen Range
Electric burner
Unplug the Range from the wall completely. Lift up the top to see under the burners and make sure they are contacting the connections for current. If they seem to be tight, plug it back in and try it. If that doesn't work, then you have an "Infinite Switch" malfunction. www.marcone.com is an excellent source for finding a do it yourself part to fix this. Please do not attempt to replace this switch with the range plugged in.
Mar 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE JBP65 Electric Kitchen Range Logo
216 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
