Question about Emerson iTone iE600BK Shelf System
How can i set the alarm and time with out the remote?
    President:
  • 1,932 Answers
Here is the manual for the iE600BK system.On page number 17 you have the steps to set time
http://www.emersonradio.com/owners/iPod%20Series/iE600_050407.pdf
Thank You
Posted on Mar 14, 2011
I have a spartus model 0105, and I need to know how to set the time.
Under the lid on the bottom left side on the top there should be buttons that say "hour" "min" "alarm" and "time". To set the time, just hold "time" then press "hour" to set the hour, and press "min" to set the minutes. You set the alarm the same way but you just hold "alarm" instead. Make sure if you are setting the alarm and time that the "PM" on the top left on the front is lit if it's PM.
Apr 18, 2015 | Televison & Video
How do I reset remote factory alarm system
try disconnecting the negative battery terminal for about 15 min and then reconnect, have remote on hand, some alarms go off when the battery is reconnected.
Sep 02, 2012 | 2003 Toyota Corolla
Can a new remote be programmed if alarm is set?
Hi Kim, When you ordered the new key the dealer should have asked for the chassis number? That gives them the codes to pre program. so that it should activate and deactivate the alarm, if that is the problem! ? Regards John
Jul 02, 2012 | 2000 Pontiac Grand Prix
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
How to set the clock
Setting the clock: press and hold the "F" button until the remote beeps twice and the hour flashes. Press the option button to go down and press the key/trunk button to go up. Once at the desired hour, press and release the "F" button to go to the minutes. Again press the option and/or the key/trunk button to set the minutes. Press and release the option button to cycle throught the other features (alarm, alarm tones, remote start countdown timer, parking meter countdown and shutdown tones). You will see "OFF" after you cycle through the alarm timer and remote start countdown timer.Press the key/trunk button to turn the feature on and/or, press the option button to turn the feature off. After you have set the time, do not press any button for approximately eight(8) seconds and the remote will exit the programming sequence and save the time.
Oct 25, 2010 | Remote Transceiver 5BCR
I changed the batteries on my F350. This set the alarm off on the truck. I cannot get it to turn off. I finally had to cut the wires to the siren. The lights still flash for a minute or longer everytime...
If it is a Ford Factory Alarm it should have key FOBS (remotes). Just press the unlock button 2 times and that should stop it. Alarm systems no matter what brand always have remotes. If you have remotes pressing the unlock should disarm the system 99 times out of 100. If that doesn't work then either the battery in the remote is dead, or the remote is broken. Hope this helps. Cobra :-)
Jun 12, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
My Python 990 system is acting up.Installed several months ago. Now doors wont lock or unlock and alarm goes off every time the door is open even in the unlock pososition. The vehicle is a 2002 Escalade...
Sounds like you have a bad remote, bad battery in the remote, or it needs to be reprogramed to the alarm. If the alarm has been set with the remote, it will need to be disarmed with the remote as well, unlocking the door with the key and getting in, will set off the viper. If you know where you valet switch for the alarm is(small black push button), just turn the key forward till everything on the dash lights up, push the valet switch for about one second and let go. The alarm should shut off in a couple seconds. This will allow you to drive the car until you get you remote checked out.
Aug 15, 2009 | Directed Dei Valet 561r Remote...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Programming factory remote on 2003 Hyundai XG350
Again, the remotes can only be programmed by a Hyundai Technician (ETACS - Electronis Time and Alarm Control System).
May 22, 2009 | Hyundai Motor 2003 XG350
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Emerson iTone iE600BK Shelf System Logo
128 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
