Question about Everex eXplora RS2800 PC Desktop
I am trying to find where the connectors go for the front panel usb to the motherboard
    President:
  • 1,623 Answers
They will connect to a usb connector on the motherboard similar to this
Posted on Mar 14, 2011
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
P6610f motherboard
Are you following Anti-Static Procedures?
If you, or the person who took it apart has not, you can use the motherboard for a Frisbee.
(Processor for a neck trinket, and Ram Memory for Christmas decorations)
Moving on.........
HP Support > Pavilion p6610f Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=4299342
Product information > Product specifications > Motherboard Specifications, N-Alvorix-RS880-uATX (Alvorix),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02560084&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4299342
A) Let's start with the two power cables coming from the Power Supply, that go to the motherboard;
1) 24-pin ATX main power cable
Looking at the motherboard photo, the 24-pin ATX main power cable's connector; is at the bottom.
Two rows of 12 socket holes, in a yellowish/whitish connector.
Motherboard installed in computer case, you will find it to the Right.
(The motherboard view shown, is clocked 90 degrees to the Right; in comparison to how it actually sits in the computer case)
GENERAL example,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connector does NOT matter ]
Note the hinged Lock Clip on the power cable's connector.
Also the TAB on the motherboard connector.
When power cable is deemed to be plugged in tightly, and properly; the Lock Clip will be over the Tab.
{Lock Clip operates on the same principle, as a see-saw on a playground. Top is squeezed in to release Lock Clip}
2) 4-pin ATX +12 Volt power cable
Looking at the motherboard photo, the motherboard connector for this power cable is;
Straight up from the white Processor socket,
To the right of the square finned Aluminum Heatsink.
General example of said power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Has a Lock Clip too.
Remember about the color of connector, thing.
Can be pink with neon polka dots. Doesn't matter.
WHAT the power cable IS, does matter.
This power cable is power for the Processor.
It ain't plugged in, you have no computer.
(Scroll down to Motherboard Layout. It is PU521 )
That's it for power cables that plug into the motherboard.
Moving on..........
The Harddrive is a SATA unit. The optical drive is a SATA unit.
(CD/DVD drive)
Means you need a SATA power cable for each one of them.
General example,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L-shaped opening in the connector. Hard to see in this photo, but I will show a better view in a minute.
Also; between a SATA data cable's connector, and a SATA power cable's connector; the SATA power cable connector is the larger of the two.
Has 15 contact pins.
SATA data cable connector has 7-pins.
Often there is a lock on this power cable's connector.
A tab that sticks up, or a 'bulb' type affair.
Depress with thumb, when plugging in, or unplugging.
Harddrive needs a power cable, and data cable.
So does optical drive/s.
B) General example of a SATA data cable, and it's respective connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Just referring to the cable shown at the top, for now.
Now you can see the L-shaped opening a little better.
See how the 'foot' of the L goes down? That is the direction you want it, when plugging in.
The motherboard connector shown below the SATA data cable, is a SATA connector.
This particular style is OPEN.
Your motherboard uses the type that is CLOSED.
Note also the L shape on the motherboard connector.
The connector shown for that SATA data cable, is a 90 degree bent elbow.
If your SATA data cables have this style of connector, they plug into the Harddrive, and optical drive/s.
The straight type of connector, plugs into the motherboard.
It can also plug into the Harddrive, and optical drive; if your SATA data cable has two straight connectors.
The SATA data cable connectors on your motherboard, are all the way to the Left. (In the motherboard photo)
Orange, Light Blue, Dark Blue, and White.
Note that they have a L shape in the middle.
Now scroll down the HP Support page, to Motherboard Layout.
Orange = SATA4
Dark Blue = SATA1
Light Blue = SATA3
White = SATA2
SATA1 is for the Harddrive
SATA2 is for an optical drive.
If you have more than 1 optical drive, it plugs into SATA3.
(Make sure SATA3 is ENABLED in BIOS Setup)
C) The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Looking at the motherboard photo, look again at the Orange SATA4 connector. To the Immediate RIGHT is the Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
I believe though, that the cable coming from the Front Panel; has one solid plug-on connector. Not individual wires.
Note how the Front Panel header on the motherboard, is missing one pin. This is the Key.
The cable connector going to it, should have one socket hole blocked off.
Should only be one cable coming from the Front Panel, that has the correct plug-on connector.
The other cables coming from the Front Panel, will have different size plug-on connectors.
Going further.........
Look at what is installed in the Front Panel;
USB ports, audio ports, (Headphone and Microphone), Card Reader, etc.
You can follow the cables, and get a pretty good idea of where they go, in the Front Panel.
For example you can follow the cables that go to the USB ports.
Follow the two cables that go to the Card Reader.
Follow the cables that go to Microphone, and Headphone jacks.
Then by process of elimination, you know which cable goes to the Front Panel header.
D) Front Audio
Looking at the motherboard photo, look towards the Top/Left corner.
The Yellow header is for the Front Panel audio ports.
Headphone, and Microphone.
E) Coming down the Left side, in the motherboard photo; look at the two White rectangular headers.
Match up in the Motherboard Layout, and bottom of HP Support page.
USB1 2, and USB1 2.
EACH USB header, is for TWO USB ports.
That is why they both have USB1 2 marked near them, in Motherboard Layout.
A Card Reader SHOULD use two cables, and One USB header.
It may be though, that the Card Reader will use both of those White USB headers.
Either the Card Reader plugs into them, or the USB ports in the Front Panel.
If the cable connector fits, plug that cable in. (On)
USB is USB.
Card Reader uses USB too.
Point?
If the cable's connector fits, plug it in. (On)
In the motherboard photo, there are two White connectors;
Above the Orange SATA4 connector, and Below the Light Blue, and White SATA connectors.
(Light Blue = SATA3, White = SATA2)
The USB ports up front probably connect to them. (Front Panel)
Follow the cables to Front Panel USB ports.
What type of connector do the cables use?
All FOUR of those USB connectors on the motherboard, may NOT be used.
Perhaps just two of them.
That doesn't 'sound' very concise, huh?
However it is my contention, that each cable coming from the Front Panel; should have a different connector.
Going further;
The Card Reader, and the USB ports in the Front Panel; may have the SAME type of connector, on the end of their cables.
Again, the Card Reader uses a USB header, (Or headers), on the motherboard.
So do the two USB ports in the Front Panel.
Therefore it does not matter which USB header on the motherboard, that either one of them are connected to.
F) Looking at the motherboard photo, look above the Ram Memory slots, to the far Right.
Right above ram memory Slot 1, that is White in color. (DIMM 1)
There is a small Electrolytic Capacitor, with a Black plastic sleeve.
Right above it is a small White 3-pin connector.
This is where the Processor fan plugs in.
(CPU_FAN)
G) Right above the square Aluminum finned Heatsink, is the 3-pin connector for the computer case fan.
SYS_FAN
(System Fan)
(The square Aluminum finned Heatsink, sits on the Northbridge chip.
Which is part of the motherboard chipset)
That about does it for me.
Please post additional questions in a Comment.
Regards,
joecoolvette
[Seems like I gave a solution for this before.
I can't pull it up in Solutions I have given, so do not know for sure.
Want to see someones user account?
If you are a member of FixYa, all you have to do is click on their user name (Example; joecoolvette), or user icon ]
Mar 23, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
How to connect the usb front panel
There are connectors on the motherboard for the usb connectors that go to the front panel. Look at you manual and connect the connectors correctly. Each connector has 4 wires, with a red(+5volts) and black on each end. Make sure plug these in correctly on the motherboard connectors since a backward connection will burn up your usb device when it's plugged into the usb port. Been there done that! It should say something like this in the manual, VCC, USB1-, USB1+, GND.
Sep 25, 2009 | MSI MS-6547 Motherboard
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
I have the same problem!!!
Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
Aug 14, 2009 | IBM (49P1599) Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Everex eXplora RS2800 PC Desktop Logo
41 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
