Question about Sony KP-51HW40 51" Rear Projection Television
Blue and green color outlines objects on screen
  • Sony Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that neblue and green color outlines - 578ba6c.jpgid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2011
  • Sony Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.Tv have R,G,B colors lines mis alignmets,have colors shadows pictures or a 3D pictures look alike?Yes.The tv convergence board is dead.Convergence board must be replaced 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Mar 14, 2011
  • 902 Answers
The way this projection screen works is with a color wheel in the back ground it will probably need to be re calibrated or the bulb in the back needs to be replaced. i had this issue with a buddy of mines not a sony model but that was the solution.
Im seeing three separate colour outlines on people and objects red,green, blue
You have a convergent problem, where the red, blue, green projector lamps are out of synch. See: http://www.youtube.com/watch?v=esk4nYZKFcg for a pictorial on how to fix convergent.
Dec 29, 2010 | Hitachi 50DX20B 50" Rear Projection...
Blurring of lettering on bottom of screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 15, 2010 | Philips 60PP9202 60" Rear Projection...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
60 inch samsung projection tv occassionally outlines the objects in pink and green.
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Televison & Video
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Green staticy looking outlines
What is model no and brand of your tv ?
How old is your TV?
Have you changed or replaced any parts recently ?
post back this details
SAM ANDERSON
Sep 23, 2008 | Televison & Video
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
