Question about Garden
The original drain valve ( drain **** ) went bad. So I bought a replacement one at Home DePot. But I tried to install it and well it barely screwed in. I thought maybe I got on to big. On the package it say's 1/4 inch. I also notice like a thread lock paint on the threads. So is this why it's not threading in all the way ?
  • 2,100 Answers
The petc0ck is 1/4 inch IP thread, or a tapered thread, It should tighten up fast, It won't go all the way in, it is tapered to tighten up and stop before it bottoms out. The thread paint is fine, a little teflon tape won't hurt anything. Hope this helps.
Posted on Mar 14, 2011
Drain valve leaks air -- no pressure in tank
Replace drain valve, its a 5.99$ at your local home depot, or hardware store. Cheers
Jul 26, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Honeywell CT3600 does not turn off heat
Its hard to say where its getting power from. It should be a normally closed two wire valve, so power must be fed from the tstat only? Not real sure how it's wired. You could try a round of MUSICAL THERMOSTATS? That would answer your question as long as its played properly.
Mar 25, 2017 | Honeywell CT3600 7 Day Electronic...
How do you clean a cold water inlet valve? Our city has had busted water lines and the silt has gotten into my lines.
unplug the washer, get at home depot "SILICON LUBRICANT", remove the fill hose, with a small screwdriver scrape the screen of the water valve and spray the lubricant to remove silt. repeat the proccess as needed. do the same at the faucet side. get new screens at home depot too. connect the fill hose at the faucet and take out the drain hose. put the other side at the drain and open the faucet to purge any dirt-silt for 2 to 5 minutes. install new screens at faucet side but not at valve side(valve has one already). open faucet and test wash. good luck to you.
Feb 07, 2011 | Washing Machines
Drain valve on Rheem water heater is cracked and leaking water. Where do I buy one and can I do the work (it looks simple) or does this require a water heater repair specialist? What do I need to turn...
You can do the job.
If the valve is plastic, the valve may break off inside the water heater.
The tank forum which is hosted by a professional plumber says, to use a hammer and screwdriver to remove the plastic drain valve: These guys are the pros.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-maintenance-tools.html
" If a plastic drain valve snaps, having a hammer, a flat-bladed screwdriver and a towel can get you out of hot water. The towel is to absorb the hot water coming from the heater. You can use the screwdriver and hammer to gently tap the broken plastic piece out of the threads, then install a ball valve drain assembly with pipe-seal tape.
Now another guy at the Tank was saying he drilled out the broken plastic valve.
In any case it can be removed if it breaks.
Install a brass valve.
I just bought one at Home Depot and noticed that Lowes has brass drain valves too.
They're in the water heater department. You need teflon tape or joint compound on the threads.
And if it ever starts leaking, you can put a hose cap on the end, or replace it again.
For professional water heater advice: I go to the tank
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 11, 2010 | Rheem Water Heaters
Leaky drain valve
Available at Home Depot, cheap and easy to replace,
Jun 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
We have a fast drip coming from the drain, what does that mean?
The pressure relief valve is going bad causing water to run out of drain line. They are easy to replace and they are a standard 3/4' threads. Turn power off and drain water down till no water comes out of drain if you lift the lever on the relief valve.
Lowes or Home Depot will carry a replacement for this heater. The T & P valve is a safety feature that will open if the pressue get's to high due to high heat in heater. With this you would get a blast of hot water running out.
T & P valve start to go bad they start dripping and evenually can not hold water back. This is a early sign for you to replace before it goes to running out.
Jun 02, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water dripping out of drain line on my Rheem Water Heater
The T & P valve is connected to the drain and it may be bad causing it to drip. You could try lifting the lever and then closing it back on it to see if it will seal. Also check the thermostat for heat setting, but than likely it is going bad.
It is a pressure relief valve and normally last about 5 years or more before they need to be replaced. The purpose of this valve is to protect heater from building up pressure and protecting the home, It releases water once the heater reachs beyond the limit of the valve can handle.
It is a standard 3/4" thread and can be removed with a pipe wrench. Just turn power, water off and drain water down to just below where the drain is.
Lowes or Home depot shoul dhave one just ask for a pressure relief vakve for a Hot Water Heater. prices range around $15.00.
May 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Went away for 8 days, came home to no water in the toilet bowl or the tank. Put water in tank, and toilet bowl, flushed, water went away and still no water in tank or bowl. Help
Thanks for all your information. A neighbour came over and saw that it was the tank valve that had broken and so he went out to Home Depot, bought the part and it's now working. Yeah!!!
Dec 28, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Washer stopped spinning suddenly
The fix was simple really. I went to Home Depot and bought a new Maytag washer. I am a genius.
Feb 28, 2009 | Kenmore Washing Machines
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
