Question about Refrigerators
LG LFX25976 French door with bottom freezer. Just purchased this about two weeks ago. Ice maker has only produced ice twice. I have good water pressure coming out the water dispenseer. I have wiped the sensors to make sure nothing was on them. The tray turns in the up right position but water is not filling in the tray. I have the freezer set on -6. I don't know what else to do.
  • John Tripp
    John Tripp Mar 14, 2011
    Are you in the USA or UK? I have all the American LG Service Manuals but that model is not mentioned, Thanks Sea Breeze
  • ginarobertso Mar 14, 2011
    US. Bought it from Home Everything.com and Home Depot has this model.
  • Refrigerators Master
  • 4,654 Answers
If you have done everything according to the owners manual on page 29 and it continues to not respond this becomes a warranty issue. I know sometimes things are sold with a defective part so if the water going to ice maker is not restricted it would need to be a problem with the dual water control valve or the ice maker itself. In many cases the customer has a defective water supply line coming to the supply end where it attaches t o base of refrigerator. Crimped line's or in some cases an old style water Piercing Valve is blocked and not recommended. Click Here for Owners Manual=> LG LFX25976 French Owners Manual and Click Here=> LG LFX25976 French... Service Manual Beyond that I do not recommend that you do anything that voids the warranty. Please Rate this solution by what I recommend and not by a mechanical solution because I in now way want to stand between the Customer and LG, If you need my assistance for direct technical answers I will be here, Thanks, Sea Breeze
Posted on Mar 14, 2011
Testimonial: "Great advice and very fast in responding"
    Thanks Sea Breeze. The service manual will come in handy when the warranty ends.
  • John Tripp
    You are Welcome Ginroberto and Thank You for the Rate!.....Sea Breeze
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
How do I remove the ice tray from LG Refridge Model # 25976
You have awater problem not an icemaker problem...inlet valve bad or water source problem....
Oct 02, 2012 | LG LFX25976 (247 cu ft) Bottom Freezer...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have had the fridge for over a year. All of a sudden the ice maker is not producing ice. I have tried turning the water line off, ice maker off and then turning them both on again.
ck the tempt of freezer it must be 15 deg or lower . then ck the water valve this is a common failure . and last it may be the ice mker itself. mm ..
Oct 14, 2010 | LG LFD25860 Bottom Freezer French Door...
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
451 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
