Question about Sewing Machines
How do i thread the bobbin through the bottom
  • Sewing Machines Master
  • 1,564 Answers
Hello:
Thread the top thread and needle. Grasp that thread then use the hand wheel one entire rotation. Pull the top thread and you'll see the bobbin thread come up through the bobbin plate. Pull until the bobbin thread end is all the way out then slide/pull both threads to the back.
Posted on Mar 14, 2011
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
The directions are very vague about how to thread the bottom bobbin. I have no idea how this is to be done or how the needle will pick it up. Help Please!
you don't thread the bobbin as such
wind sufficient thread on to the bobbin (use the rewind section of the machine )
place the bobbin in the bobbin carrier in such a manner that the thread unwinds anticlockwise
take the thread and pull it around the edge of the bobbin holder until you reach the slot in the holder
pull the thread down that slot and under the flat spring plate at the bottom of the slot
That plate controls the tension of the bottom thread
pull out about 5" of thread and while holding the thread put the bobbin holder and the bobbin into the machine making sure that it goes right in and clicks in place ( turn it to achieve the click
The needle should be fully up for this procedure
now thread the needle and hold the end of the thread while you hand turn the machine in the sewing direction
the needle will go down and if not on the first time will on the second time pull up the bobbin thread
pull that bobbin thread up and place it along with the needle thread under the foot plate and out the back comment if that doesn't work as there may be a bigger fault that can be fixed
May 27, 2016 | Sewing Machines
How do I fix the bottom bobbin thread
THE BOTTOM AND TOP THREADS ARE IN A TUG OF WAR. WHEN THE TOP IS TOO LOOSE THE BOBBIN WILL BE PULLING HARDER THAN THE TOP THREAD SO A GREAT DEAL MORE THREAD WILL END UP ON THE BOTTOM. TO CORRECT THIS YOU INCREASE THE TOP THREAD TENSION. IF THE TOP THREAD IS PULLING HARDER THAN THE BOTTOM THEN A GREAT DEAL MORE BOBBIN THREAD WILL END UP ON THE TOP. TO CORRECT THIS YOU WOULD LOWER THE TENSION ON TOP.
Dec 12, 2014 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
I have a 7570 and cannot get the tension the bottom thread is loose and can be pulled right thru I checked the top and adjusted the bottom and nothing seems to change.
When you thread your bobbin in the bobbin case, hold it only by the thread. If the bobbin and bobbin case fall, the tension is too loose. If this is the case, turn the bobbin tension screw 1/4 turn until the bobbin and bobbin case do not fall when only holding by the thread. The top tension should be set between 4 and 5. The best way to see which one needs to be adjusted is to do a zigzag. If the thread is pulling more on top and your top tension is set between 4 and 5, the bobbin tension is too loose. If your top tension is set between 4 and 5 and it's pulling on the bottom, the bottom is too tight.
Feb 17, 2010 | PfaFF Creative 7570
Bottom thread of sewing machine jams up
Try turning the bobbin around. Some bobbins should turn clockwise, some counter clockwise. What you described is what my Kenmore and Brother machines do when the bobbin is in incorrectly.
Apr 15, 2009 | Sewing Machines
Brother ls2125 bobbin not picking up thread
OK...I have an old singer (from 1964) so I am not sure whether you can do this...
I thread the upper thread as directed.
I stick the bobbin in the bobbin assembly as directed.
LEAVING THE SLIDE DOOR OPEN...I, by hand turn the wheel on the right hand of the machine counter clockwise (towards me). I want the needle go down. The thread from the upper part will enter the bobbin area and will form a loop that goes OVER the top of your bobbin to catch the thread from the bottom.
I keep turning until the machine has complete a cycle where the needle has started from the highest point, dropped to the lowest point (thus forming the loop that passes over the bobbin) and returns back to the highest point).
At this point you will notice that the thread is coming for from the bottom of the machine..I use a scissor to pull the the ends of the thread through. To the top. There should be two ends, one from the top thread, one from the bottom. If you dont believe me..jsut use a bobbin with a different color of thread...you will see what I mean..there will be two threads...one the first color and one the second color.
Good luck!!
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Nov 13, 2007 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
