Question about Franke Plumbing
I have a franke little butler, model series lb200. It is leaking around the base of the spout or the levers. suggestions?
5 Suggested Answers
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
sledge1863
  • 149 Answers
SOURCE: leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Posted on Mar 30, 2009
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
  • 297 Answers
SOURCE: repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Posted on Jul 22, 2009
I have a single lever Moen Kitchen faucet that is leaking around the base on top what might be wrong with it
You need to replace the spout o-ring seals. A Moen #117 spout oring kit. If you have a faucet with a sprayer, you will use all three rings. If uit has no spray, you will use only two.
Apr 19, 2016 | Moen Plumbing
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Franke instructions
sounds like the little butler is shorted.
Jul 03, 2014 | Franke LB1100 the Little Butler Series...
Replace Neopreme Hose on Franke FH160?
Take the whole valve and hose out and go to hardware store etc. That undersink unit is discontinued
Jul 09, 2013 | Franke LB1100 the Little Butler Series...
I can't find the reset button on my franke garbage disposal
On most franke disposers, the reset button is located inside a small indention near the bottom on the side of the unit.
Feb 11, 2010 | Franke WD-3428 Little Butler Garbage...
Garbage dispoal air switch not working
make sure the airline is secure, a slight air leak could cause this problem
Dec 11, 2009 | Franke WD-3428 Little Butler Garbage...
I just purchased a SS Franke sink which came with a single lever faucet. When you turn the spout it is loose on the base. What can I do?
There should be a large nut under the single lever faucet that can be tightened. If the sink is already installed, you will need a special tool called a "spud wrench." If not installed, you can probably tighten the nut with a channel lock or other adjustable jaw pair of pliers.
Dec 06, 2009 | Plumbing
Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
Plumbing Logo
234 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
