Question about Air Tools & Compressors
Just hooked up a U.S. General vertical 3 1/2 hp compressor and when I turned it on started to pump up the receiver. Between 40 and 50 psi the plastic tubing between the discharge line and the unloader ruptured. I cut the bad section out of the tubing and replaced the line, then the line ruptured again. Do you have any idea why this would happen?
  • 54 Answers
Is it failing at the copper/brass fitting going into the tank (the tank check valve)? That area can be 250 degrees F or more during operation. Plastic, in my opinion is not acceptable here. I'd recommend getting some 1/4" OD copper refrigeration tubing and the appropriate compression fittings, and replacing the line.
Posted on Mar 15, 2011
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
VP10 Pump,air Compressor,single Stage,3 Hp 5FTU5
3 inch pulley with a 3600 rpm motor. 6 inch pulley with 1800 rpm motor.
Nov 04, 2013 | Champion VP10 Pump,air Compressor,single...
I have a 80 gallon 5 hp ingersoll model #2475N5 serial #30T900896. Im using 10-3 wire on 40amp doible pole breaker. as its building air when it hits @50 psi it slows down. if I pull the pop off valve on...
T wo suggestions. 1- check the check valve located in top of the receiver tank by letting the unit pump up to 50 psi. shut it off and loosen the copper tube at the HP cylinder. if no air blows out the check valve is good. If it's bad it will blow until it empties the tank. If the check valve is bad replace it. 2- Tighten the drive belt. If neither corrects the problem remove the guard and rotate the pump by hand. If it's hard to rotate you have a pump problem.
May 08, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
It throws a breaker after barely even turning over. cover is off, everything seems to turn free. its a vertical.
sounds like it could be starting on load eg starting against a pressure, if you drain the receiver down will it start ok then, if so you probably have a faulty non return valve letting pressure back onto the head. If it is not that the capacitor on the motor could be faulty.
Jan 17, 2011 | Craftsman 33 gal Air Compressor 6 hp...
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have an Ingersoll Rand compressor (RA5E6VA) 5 HP 60 gal vertical tank (only found 3 HP listing below, but it says 5 HP on it) There is a plastic tube between where the pump attaches to the tank (air in)...
that is just a compression fitting. Sometimes just replacing the tubing is enough to get a bit on it. If not you should be able to get another fitting from an indstrial supplier.
Mar 06, 2010 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
What horse power is required for producing 16.9 CFM at 100 psi or what horsepower is required to produce 16 CFM at 175 psi We have an air dual stage air compressor and need to find a motor to fit that will...
You are looking for about 5 H.P. to do that, but what is more important is the r.p.m. of the motor, the size of the pulley,,, and the size of the compressor pulley! most manufactures will spec the pump for certain horse power,,, they go hand in hand,,, for example you cannot take a pump designed for 5 H.P. and hook a 10 H.P. motor and a bigger pulley on it and spin the pump faster to make more air,,, it wont take that high of speed,,, I hope this helps.
Feb 25, 2010 | Campbell Hausfeld Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
