Question about Kyocera Copystar CS2540 Copier
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
  • 200 Answers
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Posted on Mar 22, 2011
Machine failure
what error code?
Dec 06, 2014 | Copystar Cs-400ci
Why is there a error message of tray failure?
tray is out of order for a reason, needs resetting via sim 906
and checking lift motor.
Jul 28, 2014 | Kyocera Copystar CS-2560 Black and White...
What is the error message PF on the CS-1810 mean?
PF means paper feed. When the machine attempts to pick and finds there is no paper the error appears.
Sep 13, 2010 | Copystar CS-1810 Copier
On the copystar 1815 I have an error message that says 'error occurred call service person'. On the bottom of the screen it reads 'C6400". I can not clear it. Help!
when machine is on hold down stop key, start, left exposure. release them and press start. display will show U000. self status. key in 163 and press start twice
Jul 31, 2010 | Copystar CS-1820 Copier
I have a kyocera cs-1650 with the error message FAX MODE ERROR. can you help?
It is problem Program not properly configure.set up fax program,Fax line type,Receiving mode,number of ring count.Other help follow your copier User Guide manual.If you do not fix your problem then you call a service technician. who support this machine.
Dec 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Dec 04, 2008 | Copystar CS-1505 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Kyocera Copystar CS2540 Copier Logo
288 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
