Question about NRS Wayne& Lawn Sprinkler Pump
WAS PUMPING FINE FOR THE 1ST USE OF THE SEASON,WORKED FOR ABOUT 5HRS. THEN MOTOR WAS RUNNING BUT IT WAS NOT PUMPING WATER. THOUGHT IT LOST IT'S PRIME SO I PRIMED AGAIN WITH NO LUCK. THOUGHT I HAD PROBLEM WITH SUCTION LINE, SO I MADE A NEW CONNECTION AND RAN IT INTO A BUCKET OF WATER TO SEE IF IT WOULD DRAIN THE BUCKET, IT DID NOT.NEXT I CLEANED THE IMPELLER, STILL NO LUCK. THE PUMP IS ONLY ONE YEAR OLD. HELP!
    Sergeant:
    Champion:
  • 333 Answers
May have lost it's prime fill the pump with water
Posted on Mar 16, 2011
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
Dec 19, 2011 | Sta Rite Pool & Spa
Pump motor functions normally, pump is not circulating water. Where does the problem lie?
1ST THE PUMP NEEDS TO HAVE WATER TO IT (PRIME) NEXT CHECK THE IMPELLER , IS IT PLUGGED , OR BROKE AKA MOTOR RUNS BUT IMPELLER DOESN'T TURN (( COMMON ) . HOPE THIS WAS OF HELP.. VOTE AND TRY TO BUY USA MADE PRODUCTS .. JAY
Nov 24, 2010 | Garden
Pump hums
prime the pump.Put some water in it
May 20, 2010 | Polaris Pb4 - 60 Booster Pump
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Lost my prime in my pump, i have tried numerouse time fill the basket area with water turn on pool pump nothing, any more suggestions. I lost my prime to my pump a few weeks ago . I had a pool company...
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Apr 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
NRS Wayne& Lawn Sprinkler Pump Logo
116 people viewed this question
Top NRS Pool & Spa Experts
Ian Kime
Ian Kime
Tom Chichester
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
