Question about Ricoh FT5832 Copier
My ricoh FT4418 wont copy at all error code E70. what does that mean?
  • 32 Answers
It means the toner overflow sensor was tripped: http://www.copier-help.com/copier-help/ecs/ricoh/ecrft4418.html
Posted on Mar 14, 2011
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Error code E70 on ricoh FT 4418
Empty the waste toner tank.
1. Open the front cover
2. Lower the transport unit
3. Pinch the cleaning blade release lever and slide the cleaning unit out.
4. Remove the 4 screws in the top cover of the unit.
5. Dump out the waste toner.
Mar 14, 2011 | Ricoh FT5832 Copier
Depending on which paper tray you select, one of two error message is flashing on the readout: E70 or -A4. We cannot detect a paper jam. What do these codes mean and how do we correct it?
the error means that the size of the original does not match the size in the paper tray. select the tray you want use withe paper select key then make your copies
Feb 14, 2011 | Copystar CS-1500 Copier
Error code E 1 on my Ricoh FT4418
please press (.) so we could see the last two number. but most probably check your exposure lamp and thermistor. maybe they are busted anf need to be replaced.
Feb 03, 2010 | Ricoh FT5832 Copier
ERROR MESSAGE ON RICOH BLACK AND WHITE FT3713 ERROR E70
Waste toner is full. Remove cleaning station, empty waste hopper, and run "SP83" to clear code.
Apr 22, 2009 | Ricoh FT3713 Copier
E70 error code
You didn't include the model number, but it sounds like a ricoh FT3213 or 3713. If your not a tech, and it sounds like your not, then you'll need to call one. The waste toner is located in the cleaning section, and it needs to be emptied, and then reset in service mode with "SP83" which will mean nothing to you.
Apr 03, 2009 | Office Equipment & Supplies
Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Dec 09, 2008 | Ricoh Aficio 1035 Copier
Ricoh ft3713
Please properly installed the Drum Unit
Sep 22, 2008 | Ricoh FT3713 Copier
Ricoh FT3713
Try to properly close the cover and also the Drum Section
Sep 22, 2008 | Ricoh FT5832 Copier
Ricoh FT5832 Copier Logo
161 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
