Question about Microwave Ovens
Disposal won't start. Is there a reset button?
  • 604 Answers
Usually on the bottom of the unit, but first check to see if you have voltage to the device. if it hums when you turn it on, its getting power and may be jammed with something. first make sure its not being jammed by something. On the bottom of the unit is an allen wrench slot that you can use to turn the motor by hand, this will sometimes free up a stuck disposal.
Posted on Mar 14, 2011
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave oven fan
Depending on the age of the unit, with the minimal cost of newer ovens these days, you're better off checking with your local municipality for proper disposal directions and buying a new one.
Apr 27, 2012 | Hotpoint RVM1435 Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Garbage disposal is not working. There doesn't seem to be anything in it and resetting and unplugging/replugging hasn't worked. Do I have to take it apart?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 25, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
Is there a reset button on a emerson garbage disposal model e404?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Jan 05, 2011 | Emerson Microwave Ovens
Blades don't rotate when unit is turned on
does the unit make any noise?? if so its prob bad..replace!....if no noise check under unit, there is a small red reset button..push up firmly.. turn on...keep fingers out please!
Mar 15, 2009 | Microwave Ovens
Microwave Ovens Logo
11 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
