Question about Panasonic RF-SW200 AM/FM Radio
How do I unlock Panasonic RF-SW200 ? - Panasonic RF-SW200 AM/FM Radio
What is the wiring color code for a sony cdx-sw200
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope that is what you were asking for.
Nov 08, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Feb 23, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Jan 26, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Can't figure out how to change the time
Press DSPL for 2 seconds
Press the + or - volume buttons to set the hour
press SEL
Use the volume buttons to set the minute
Press DSPL
Jan 05, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic RF-SW200 AM/FM Radio Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
