Question about Schumacher & Fast Charge Starter Charger
When I plug in the mity mite the red led does not come on showing it is charging. Instead the green light is on. When I push the test button, the red light comes on showing it needs to be charged.
2 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: Schumacher Mity-Mite model PS-70A. I want to
http://www.alibaba.com/product-gs/206111785/dry_type_deep_cycle_battery_12V.html
Does the above fit the description of having solid tabs with holes?
Or is this the quick connector type?
Posted on Jul 13, 2010
When I changed the battery it has a red light instead of green. Not sure if its working properly or not.
is the battery fitted
fully charged/new and
connected positive and negative correctly
Jul 31, 2016 | Home
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
How do i pair HP500BT with device
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Dec 28, 2013 | Technical Pro HP500BT Wireless Bluetooth...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Jul 13, 2010 | Schumacher & Fast Charge Starter Charger
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Jul 17, 2009 | Culligan Under Sink Water Filter
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Schumacher & Fast Charge Starter Charger  Logo
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
