Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
The sweep tail doesnt sweep - Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
  • 640 Answers
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Posted on Apr 12, 2011
Water comes out of the tail of polaris 360, but tail does not sweep.
check the filter in the wall of the pool where the Polaris line hooks up, it got a small filter in it. you are running it on low-pressure that's why it not sweeping, could also be a plugged impeller on the booster pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 21, 2017 | Polaris Pool & Spa
How do I get a polaris sweep tail to work
A 360 works off of the main pool circulation systems return line.
Is the pool pump on?
Is this a pool/spa combo?
If so, then is the water returning to the pool or the spa? It should not be returning to the spa, dial it back some.
Is water coming out of the dedicated inlet fitting that feeds the 360?
If not, find out why, this is the problem.
If there is water flowing out of this fitting, then the pool sweep itself has something stuck in the drive axle or in the drive wheels.
You could also have "Stripped" gears/teeth on the the 2 front drive wheels, if smooth, (if sections of the two front wheels are smooth where there should be teeth), then replace them.
Take a look at the pic below, you should be able to see the teeth on the inside of the wheel.
Good Luck
Feb 21, 2015 | Polaris 360 Pool Cleaner 360
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
496 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
