Question about HP 530 Notebook PC
How to get the maximum screen size on hp30? - HP 530 Notebook PC
  • joegrindz44 Mar 14, 2011
    how about on windows vista?
  • 32 Answers
Is this in Windows 7 or Windows XP?
In XP: Right click on the Desktop. Hit properties. Click the advanced tab. Drag the resolution slider all the way to the right.
In Windows 7: Right click on the Desktop, click screen resolution. Follow the on-screen instructions.
Posted on Mar 14, 2011
Compaq desk top screen to large
Right click your desktop and click resolution. Adjust it so that it is set to the maximum possible (native) and click apply. If you're talking about metro, you should be able to scroll scroll to reach the other icons. You can also adjust icon screen size if you go to the desktop, hold the control key and scroll using a wheel, or right click and change icon size.
Nov 04, 2012 | Compaq Computers & Internet
Can you restore my laptop screen to full size at the moment it is half size
Open up a web page on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size % click a different percentage
also a text size you might try a different text size although this will not increase the size of the page only the text inside it
if you do not see these tabs in the top toolbar right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
right click in the top toolbar select the menu bar this will add the menu to the toolbar then select the view option then from the drop down list select full screen
alternativevly
Change the resolution of the screen to its maximum in cases where the screen size has been compromised due to selecting a non-native resolution.
To accomplish this, right click on the desktop and select the option to "Personalize."
From there, click on "Display Settings," then slide the resolution bar all the way to the right and press "Ok" to confirm your choice.
This should restore your screen to its proper size.
hope this helps
Sep 17, 2012 | Dell Latitude D 630 D 640 D 520...
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
My H-size and V-size are at maximum 100 but the screen but screen is still small for the monitor size...what could I do to fix this??
There are two ways to adjust the picture, the best way is simply to use the buttons on the monitor, if that doesnt work negotiate to the software adjustments by right clicking on the screen and going to properties.
Nov 04, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
I have bizhub c350, everytime i scan to email i get multiple emails each with 1 page. how do i fix this?
If you go into the admin setting when using the web browser you can enter the email setting one of the options is binary, if you turn off or on depending on the setting it should stop this fault.
Mar 02, 2009 | Minolta C350 Color Printer/Scanner/Copier
What is the maximum size of HDD supported on a mother board say MSI board say - K8MM-V (MS-7142) ? How do we detrmine this value ?
Dear sir,
i dont think there is any maximum size of HDD supported by any motherboard.....
But now a days 320 GB is the maximum size of HDD attached with any pc....
do reply
Abhinav
Jan 23, 2009 | MSI K8MM-V Motherboard
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
I get the warning virtual memory minimum too low how do i fix this
Very simple .just goto control panel >Double click on system >Select Advance tab >Under Performance tab click on Settings >Select Advanced >Under Virtual Memory tab click on Change,
Now select custom radio button
Now you will some thing like this
Initial size(MB) = 768
Maximum size -1024
Now here comes the main point and to enter proper values under Initial size (MB) =
and Maximum size =
suppose your ram is of 512 mb than initial size will be
Initial size = 768 ( 512 * 1.5 = 768)
Maximum size = 2304 ( 512 * 1.5 * 3 = 2304)
just enter the values according to calculation and your problem is solved ..if you want you can increase more 'Maximum size' value for faster system optimization .
_____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 08, 2008 | Computers & Internet
HP 530 Notebook PC Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
