Question about GPS
I installed tomtom to my n958gb and on setup i picked the blue tooth setting for connecting how do i change it to another setting
Menu: Preferences -> GPS Status -> Change
Next -> Done.
Posted on Jan 16, 2009
Can i use an external keyboard to access my nextbook with a cracked screen?
Perhaps, when you can setup the blue tooth connection and don't need to install any app before starting the keyboard.
Mar 16, 2015 | Nextbook Tablets & eReaders
Blackberry pearl - TomTom 920 compatibility
Greetings,
Looking into this I have found that they only blackberry firmware that is compatible with TomTom Plus services is 4.2.1.66 found here:
https://www.blackberry.com/Downloads/entry.do?code=1D72310EDC006DADF2190CAAD5802983
I scraped the rest off a forum and will paste it below. It seems to me that it is a lot of trouble for not a lot of payoff. Good Luck!
ou can still get the 4.2.1.66 version here: https://www.blackberry.com/Downloads...190CAAD5802983
from Italy downloads but don't worry, it's Multilanguage. The Package Version is 4.2.1.102.
Install BlackBerry's Desktop Manager, I used version 4.3. Then remove the .bin (dot bin) from the 4.2.1.66 version you downloaded and run it letting it install itself. Then goto /Program Files/Common Files/Research In Motion/Apploader on the disk you installed the Desktop Manager on and rename vendor.xml to vendor.xml-save. If you don't do this the Desktop Manager will not offer to install the the 4.2.1.66 Italy version. (Unless probably you have an Italian provider.)
Then, you still have to do a manual setup of the phone in the TomTom setup.
1. Let the TomTom find the BlackBerry and Confirm connection to it.
2. Set it up as a trusted device on the BlackBerry.
3. Use TomTom services --> Yes
4. Country: United States
5. Select your Provider --> Other
6. Do you want to set up wireless data connection manually --> Yes
Access Point Name --> wap.voicestream.com
Username:
Password:
Obtain IP --> Automatic
Obtain DNS --> Automatic
Dial --> *99#
Login script --> at+cgdcont=1,"IP","wap.voicestream.com"
7. OK and it should connect!
Note: Attempting to use internet1.voicestream.com, internet2.voicestream.com, or internet3.voicestream.com as the TomTom attempts to do if you pick T-Mobile (I) thru (IV) did not work.
Since the first phone I tried was the T-Mobile Shadow I signed up for the Total Internet Plan, now that I have the BlackBerry I changed that to the BlackBerry Unlimited Plan but T-Mobile says it takes 2 to 48 hours to provision that so if this still works on Tuesday I'm good to go.
The trick to getting this working was to do a Factory Reset on the GO 720. Bingo. It worked. You still have to use wap.voicestream.com instead of internet2.voicestream.com (or any other number). So you can pick T-Mobile (I) and let it fail then choose to do a Manual setup changing the APN to wap.voicestream.com and accepting the default for the rest, or you can do a manual config from the get go and enter the APN, number to dial, and the connection string a.k.a. the Login Script on the TomTom.
And another thing, on the 8120 under Settings --> Advanced --> TCP the APN: value should be blank.
See http://www.tomtomforums.com/showpost...&postcount=121 for more info.
May 12, 2008 | Tomtom GO 910 GPS Receiver
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
Connecting epson wireless printer
There are two ways to go about this. You can either Blue Tooth your printer direct which you will have to enable Blue Tooth connectivity on your printer in the set up menu. The other way is to run it through your router. For that you need to run a data cable from your printer to your router. Once that is connected you can install your printer using the Devices Setup Page in your control panel. There is also an add a printer option as well.
May 11, 2014 | NetGear Computers & Internet
Rename C hard drive correctly.
First,you didn't post the Make, model of laptop or the OS you are using? Second have you unplugged and removed the battery in the Laptop, plugged in, rebooted? Can you enter BIOS setup? At boot try a System Restore/Recovery.
Mar 02, 2013 | Computers & Internet
Have new lap top [toshiba satellite] have connected tomtomgo 520 twice and on both occasions my wi fi connection has been disabled
Built-in FM Transmitter to transmit sound over own car stereo and lets not forget Best hands-free calling> Best guess is that your computer is finding and trying to connect to the blue tooth connection since Toshiba has blue tooth capabilities, also you could be losing the wifi signal just because the FM transmitter is overpowering the the wifi signal. If i had to guess though i would go for the blue tooth connection as being the problem. Hope this helps
Apr 26, 2010 | Tomtom GO 520 GPS Receiver
Adjusting Clock on Tom Tom 950 +Mobile Phone to bluetooth
is all in the menus. go tomtom.com, sel support, search for change time and later for blue tooth, sel device and do as told.
Feb 11, 2010 | Tomtom ONE GPS Receiver
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Blue tooth
try 0000 worked for me!
Dec 17, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
32 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
