Question about Campbell Hausfeld 8GAL Air Compressor
The compressor initially starts for 4 seconds and then just cut off. what must be the cause?
    Sergeant:
    Champion:
  • 250 Answers
You could have a bad cutoff switch or the switch is not set right or if the motor feels quite warm the motor is shutting off whith its overload sensor.
Posted on Mar 14, 2011
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
What can make diesel engine to vibrate surdenly when the engine is running on load from a air compressor
When the compressor starts, initially there is a very large current draw by the compressor motor. Depending on the size of the generator and compressor motor, this could cause the generator to stumble for a few seconds, but this should smooth out within 3-5 seconds.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
G.e. air compressor motor cuts on then cuts off
could be one of 3 things
not enough amperage in the circuit, needs a 15amp circuit
run/start capictor shot
pump motor seized
Mar 06, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
I have a D55155 Dewalt air compressor. When I flick the switch to on the compressor sounds like it is starting very weak and then dies. A couple seconds later it repeats. Anyone know what this could be?
Yep! 2hp compressors need a strong power source. They'll draw alot of amps on initial startup. If they aren't getting sufficient power,they'll act just like this. It's causing the compressor's circuit breaker to cut out. Then when it cools off, it'll reset.
My suggestion is to avoid using extension cords if at all possible. The longer the cord, the harder it will be to start.
Try to plug directly into an outlet. If you need extension cords, use the shortest length possible. Also make sure the wire guage in your extension cords are no smaller than a 12guage wire(the higher the number, the smaller the wire guage).
Jan 02, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Fridge/freezer,wbm39 MS. Motor cuts out after about an hr.
You need someone to open the cover on the compressor and examine or replace the start relay, start capacitor and motor windings. One of those 3 are not working properly.Is the model number you gave made for and sold in the UK? Sea Breeze
May 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
96 Honda Accord LX 4 cyl - ac goes on/off every 15 seconds
when the compressor cycles fast that usually means that its low on freon.use approved gauges to get good pressure readings.
May 05, 2009 | 2004 Honda Accord
Fridge and freezer not working, compressor starts but keeps cutting out after about only 5 seconds.noticed compressor very hot(is this normal).
Replace the start relay on the compressor.
Unplug it until you get the part or it will cause the compressor to fail.
Mar 10, 2009 | Candy CPCA270FFK Bottom Freezer...
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Campbell Hausfeld 8GAL Air Compressor Logo
105 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
