My friend has a Toshiba laptop, I'm not sure the exact one, and she says her mouse pad won't work. We've tried the Fn and F1 keys, restarting and several other things but it's still locked/dysfunctional. What can we do?
    Master:
  • 525 Answers
Make sure the drivers are installed. you can find them on toshibas website.
Posted on Mar 14, 2011
I've just bought a new Acer Aspire 5742Z and the smart pad has suddenly stopped working. Any idea whether it's likely to be a hardware or software issue and how to fix it? I've tried...
Hi jennylewry...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 10, 2011 | Acer Aspire One PC Notebook
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
Sep 05, 2011 | Toshiba Computers & Internet
Cannot get touchpad to work on my laptop keyboard, I just had my laptop converted into a desktop. even the buttons underneath the touchpad are not working. HELP!
In Windows XP:
Click START
Then SETTINGS
Then CONTROL PANEL
Then MOUSE
Then DEVICE SETTINGS tab.
Cilick ENABLE
Then APPLY
Then OK.
Restart computer if necessary.
Mar 01, 2011 | Computers & Internet
The mouse pad is not working. Is there a way to turn it back on?
There's a keyboard combination to turn the touchpad on and off. It's usually the Fn key plus one of the F1-F12 keys. On mine it's Fn+F7 but that doesnt have to be the case with your laptop. Look over the F1-F12 keys and look for a rectangle logo. Dont mistake it for the toggle LCD-External Monitor key). Just try them out and see which one it is. If you mistakenly turn off your LCD just repeat the keystroke combination to turn it back on. This should be a straightforward try-fail thing. I once reinstalled everything on my old Toshiba because I mistakenly turned off the touchpad without even knowing I did so. :)
Jan 14, 2011 | Dell Inspiron M5030 Laptop
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
Mouse pad doesn't work
On the laptops keyboard you should find that one of the F Keys (ie F3) will have a picture that looks like to touchpad on it. If you press and hold the blue FN key in the lower left of the keyboard and then the F Key that might restart it working again. Good Luck
Rytech Computer Services Limited.
Oct 11, 2010 | Toshiba Satellite A135-S4527 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Mouse pad not moving the cursor
There will be a Fn combination for the mouse pad.Please have a look on the fn (F1 to F12) keys on top of the keyboard and you will find the mouse pad symble on any one.
Press that function key with fn key (usually with windows button) and the touch pad will start working.
Thanks.
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cursor will not move on screen when using touch pad i've shut the computer down and restarted but cant get the cursor to move
Please press Fn+F9 key to ensure the mouse pad isn't disabled. The key should have these symbols on it.
Hope this helps,
NOLA Tech
Jan 30, 2010 | Toshiba Satellite Pro P300 Notebook
Mouse pad stopped working after kids pressed
I'm assuming you are talking about the touchpad - they may have hit one of your hotkeys - fn+f7 will toggle the touchpad on and off - on my aspire 3050 anyway - try fn+f1 to get a list of the hotkeys and what they do to make sure
Apr 17, 2009 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
