Question about Sony DTC-ZE700 Dual Cassette Deck
Stops after 7 seconds
In record or play, the transport stops after 7 seconds. Even with the cleaning tape.
  • Doug Dahlgren Aug 01, 2008
    Wow....That was fast! I'll try to find the area of which you speak. (This is my first time here)
    Thanks,
    Doug
  • 10,594 Answers
Its issue of Take-up Reel Sensor signal. Please check concern / related area
Posted on Aug 01, 2008
  • Shahid Electronics
    Shahid Electronics Aug 01, 2008
    Remember my Nick Name for Sony products. :)
  • gcwaite Apr 20, 2011
    Could you elaborate on this answer? What do you mean by concern / related area? I have the same problem with my DTC-790. THANKS
Audio recorded, but do not play back fully
Can you tell me about the phone you use (In detail)?
I will help you with a sol'n Insha Allah
Nov 18, 2013 | Mamoru Tokashiki Voice Recorder
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
My Panasonic AJD230 is spitting out some but not all, tapes
The capacitors are old and need replacing. And what I mean by caps is ALL the caps. These decks are known for failing capacitors - even if the deck hasn't logged much play/record time - time is not kind to them. Panasonic have ready made capacitor sets for the decks and even though you might be able to fix your transport problems by replacing only a portion of them, it's advised they all get done at once. That's between 10-20 hours for an experienced tech and it will cost you. What can you do?
Oct 26, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Playing a tape on Deck B stops after a few seconds. Tried over and it stops again after a few seconds of play.
Either tape is tight, run it ff the rev all the way back, or transport is failing , motor , belt , pulley etc,
check tape or try another one in deck b, how is deck a
Sep 21, 2009 | Onkyo TARW255 Single Dual Cassette Deck
How can I get VHS tapes to play?
try to run a vhs cleaner thru it and it should help alot
Jul 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Emerson EWV403 VHS VCR stops taping and powers off spontaneously
There are probably a few different ailments which can cause this. One is if something is afoul in tape transport. I'd think the problem would occur whether in record or playback however.
If the tape takeup reel drive is slipping, tape takeup might intermittently stop, and cause the machine to power off (this is to avoid spilling tape in the machine). With the cover off, insert a tape, hit play, and see if tape takeup is steady, especially nearer the end of the tape, when the right reel is filling up.
An associated problem is if the reel sensor is intermittent- this sensor tells the logic whether or not the takeup reel is turning- again, this is to avoid massive tape spillage and damage.
Another possibility is a dirty mode switch- this switch tells the logic circuitry what position the mechanicals are in. It is probably located on the underneath side of the deck. Sometimes it can be disassembled and cleaned with a cotton swab wetted with contact cleaner. Others must be replaced.
Hopefully this helps- perhaps another tech has a better solution too.
Nov 12, 2008 | Emerson EWV403 VHS VCR
Pixelated recordings
clean heads and tape transport with head cleaning tape, worked for me. had to run the tape 3 times at 10 second intervals with a 30 second cool down between runs. Dont clean for more than 10 seconds at a time as the cleaner tape heats up head and will fuse dirt onto head if overheated.
Jul 07, 2008 | JVC GR-D290 Mini DV Digital Camcorder
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
Sony DTC-ZE700 Dual Cassette Deck Logo
316 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
