Question about Kenmore Dryers
Hi have a lady kenmore dryer and not providing heat. Air is on and tumbling but no heat. Lady Kenmore Model 110-86992100.
  • Mark Nichols Mar 14, 2011
    HAve to run a series of test could be the element, could be a thermostat. Fixable and I have discount parts... If you want to tackle this i can help toll free 877-293-1739
reg501
  • 413 Answers
SOURCE: I have a lady Kenmore
The heater and thermostats are easily accessible in in the rear by removing the back panel.
Posted on Jun 22, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore gas dryer does not heat.heating element
Your gas dryer uses a pilot-less burner assembly that has an electric igniter. It is designed this way to prevent free-flowing gas from filling up the appliance cabinet without ignition. Such a condition could cause an explosion. The way the ignition system in most of today’s appliances work is like this:
1. Press the start button.
2. The igniter on the burner assembly begins to glow.
3. Once the igniter reaches the required current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
If you are having problems with ignition, it may be something as simple as a bad igniter. Just because an igniter glows, does not necessarily mean it is good. They do become weak with age and if they do not draw the required current potential, they will not allow the gas safety valve to open. There are two basic types of igniters:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
Your igniter appears to be the Norton type. The part number is 279311 and can be purchased at pcappliancerepair.com for about $22. Instructions should be included with the parts kit. NOTE: If the igniter connector plug does not match the one you have, there are instructions that explain how to cut and splice the connections using a set of ceramic wire lugs included with the kit. Do not use standard wire lugs as they will melt due to heat. CAUTION: Make sure you unplug the dryer and turn off the gas source prior to servicing.
If you have questions, or require additional assistance, please post back so I may be able to assist you better. I hope you find this information helpful. PS Use model number 110.76912690 for your search criteria.
Posted on Aug 26, 2009
iwillfixforu
  • 619 Answers
SOURCE: I have a Lady Kenmore electric dryer (40 years old
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Posted on Jan 31, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Lady Kenmore 110 model 86692100 stopped tumbling, still gets heat and can hear blower running.
Sounds like a drive belt. You can change it youtself if you are fairly mechanically inclined.
Open the cabinet by sliding the top forward until the clips in front allow the front edge of the lid to lift, hinging at the back. Once open you should be able to see if the belt is loose or broken by checking it as it goes over the top of the drum. If it is broken, remove the front of the cabinet and install a new belt. (Your local Sears store should either have one or can ship one to you.) When installing the new belt, you will need to make sure to snake it around the tensioner pulley. This can be a little tricky but when you see the direction it is sprung, it will make sense which way to wrap around the tensioner pulley.
Best of luck
Feb 24, 2011 | Kenmore Dryers
The drum turns but I have no flame on my lady kenmore dryer model 6607921
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Dryers
I meed a belt for lady kenmore dryer part #688673 revb
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Oct 06, 2010 | Kenmore 2666814 Dryer
My Kenmore Elite dryer will not heat. It tumbles
REPLACE THE ELEMENTS, YOU CAN CHEC THEM WITH AN O METER TO SEE IF THEIR NORMALLY CLOSED AND NOT OPEN, BUT I WOULD THINK THIS IS THE PROBLEM IT USUALLY IS
Jul 10, 2010 | Kenmore Dryers
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
Jan 31, 2010 | Dryers
I want to remove the heating element from a Lady Kenmore dryed # 110 76694100. How do I access the element and where is it located?
Should be located in the back of the dryer...remove the panel from the back of the dryer, and look for the dryer air tube coming from the fan...the element should be in there
Sep 22, 2009 | Kenmore Dryers
Lady Kenmore electric dryer broken start button
it is time to replace it, that sound and smell is from the dryer motor itself.
Jun 28, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
