I have a simpson swf8556 front loader machine, after washing and the OK light is on it will now not allow me to open the door to retrieve clean clothes
  • Chris Burow Aug 21, 2013
    You need to switch the knob to the off position, don't unplug or disconnected the power, and wait for 3 minutes. The washing machine will eventually reset and release the lock.
  • 641 Answers
SOURCE: GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
  • 1294 Answers
SOURCE: Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Posted on Sep 21, 2007
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
Karthik316
  • 187 Answers
SOURCE: Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Posted on Jul 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Simpson esprit 550 top loader washer
Have you tried the motor control switch.
Its located below the selector switch.
Its white aprox 5 x 7cm with Electrolux AMD103 stamped in it.
The wires that are plug in it goes to the selector switch.
Apr 30, 2016 | Simpson Washing Machines
I have 5.5 kg front loader simpson EZI sensor washing machine,the handle to open the washine machine has gone loose and now can not open my full load of washing from the machine
you need to take the top off turn off the mains supply
and reach down to the door catch behind and manualy open it
if the handle has cracked a the pivot pehaps a flat blate screwdrive and you can carefully release it
youll find a littl preasure to the door will help you then let go and the door will open easier
Mar 02, 2015 | Simpson Washing Machines
My door handle has snapped off my simpson ezi sensor front loader , how do I open it until I gets repaired ?
Put your question in the washing machine section
This is only a chat room
No one home at FixYa-- just a free website
No guarantee you will get an answer
Aug 30, 2013 | Washing Machines
Hi, Weve got a simpson esprit 700 washing machine and the cold water tap seems to be blocked. I've disconnected the hose at the washing machine end but when I've turned it on in the sink it works fine so...
Hi just read your posting.There are 2 types of SIMPSON ESPRIT washing machines,There is a top and front loader version.Which one is yours?Please reply and I will guide you on replacing the water valve.Looking forward to your reply.
Sep 19, 2010 | Washing Machines
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do i clean the mould off the door seal to my front loader and keep it clean?
bleach and water ..fill washer with hot water por in about 2 cups chlorine bleach allow to mix.. open door and using rag wet rag soaked in solution wash all around door seal be sure to roll seal out toward front and wash lower part to close door and allow to finsih wash and rinse cycles do on reular basis and leave door open as much as possible to air out
Nov 02, 2008 | Washing Machines
Washing Machines Logo
656 people viewed this question
Top Washing Machines Experts
