Question about RCA Audio Players & Recorders
I have a RZC 298W RCA FM/AM tuner/stereo amplifier that I cant find anywhere. It works ok, except its fuzzy. I'm Just curious about schematics and what year it is. it looks like its at least 40 years old. Can anyone clue me in. the model # is 14560011
  • 604 Answers
You could contact a tv repair shop, many shops have schematics that go back many years. You say the sound is fuzzy, is this fuzzy sound when your playing the radio or when you play something throgh the amplifer? If its fuzzy with any source the you might have a bad speaker or speakers. you need to be more discriptive of the fuzzy sound you describe. also. if this unit has a head phone jack, (which I doubt if its 40 years old). you could plug in some head phone and see if the sound is clear there, if so then you know its most likely the speakers.
Posted on Mar 14, 2011
Fuzzy sound out of one speaker, goes off after it warms up
If i were you i would double check wiring and connection for that speaker in particular. then user process of elimination to make sure its the speaker/wire or the port that is distributing the music. you can do this by switching speakers of the ones that are functional and test them. this will help you narrow down your answer
Nov 03, 2015 | Marantz Vintage 350 Stereo Amplifier & Mt...
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
The picture quality is fuzzy at the lower left of the screen. Also, the DVD picture is off center. How can I adjust or reset both?
This indicates an Automatic Gain Control (AGC) problem often caused by a dried up capacitor. You will probably need a schematic to go much further. This could be a problem in the tuner, IF, or video amplifiers.
The following assumes you are sure the signal source is strong - try a VCR or other local one (channel 3/4, not the RCA jacks).
Most of the time the range of AGC is from 1 to 7 volts. If you can get a decent snow free picture with an external AGC source, then the tuner is probably OK.
May 21, 2010 | RCA D61W20 61" Rear Projection Television
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
Nov 13, 2008 | Car Audio & Video
134 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
