I disconnected my computer from everything when moving in office and then re-connected,but my screen monitor would not 'fire up' I had to fool around with the keyboard and finally it would fire up. The other day, I reconnected my webcam and microphone and it now fires up right away ???
  • 604 Answers
Is there a question in here somewhere?
Posted on Mar 14, 2011
HPw2338h screen is black and says going to sleep?
They usually go off when the don't detect a signal from the computer, make sure the connection is ok between them.
Jan 28, 2012 | HP Computers & Internet
My screen suddenly developed horizontal lines in it. I tried everything, but the only thing that worked with "Memory Recall", which as I understand it, changes the settings back to the original...
It sounds like you have an issue with the monitor's power. Make sure all connections with the power cord and audio cables are secure. If this does not resolve the issue and the monitor is under warranty you may want to RMA it.
May 27, 2011 | ViewSonic VA1912wb Monitor
I have a Gateway Laptop and a ViewSonic monitor and relocated them into my office yesterday. The ViewSonic was working fine. When I booted everything back up the Viewsonic turns on, flashes my...
It means that there is no video signal from your video card. 1. Check the video cables 2. Try connecting your internal video card if you have one or change the card with new one.
Feb 28, 2011 | ViewSonic VX1935wm LCD Monitor
My computer wont start, no setup, no bios, nothing...
This is only a stab in the dark but are all your M/board fixing connected correctly
Hard drive etc.
One other way is to disconnect everything from M/board except for Video and memory and try to boot up if it does then connect hard drive etc one at a time rebooting each time until it will not boot that is the wrongly connected one
Oct 17, 2008 | Mach Speed MS945G-GLV Motherboard
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Computers & Internet Logo
David Payne
David Payne
