Question about Harman Kardon Audio Players & Recorders
I have a harmon kardon av 20. everything worked fine, lastnight i switched from my tv sound to the tuner and now no sound at all. i tried different speakers, and ohmed out my old speakers. any ideas?
    Brigadier General:
  • 8,546 Answers
For NO SOUND problems, FM is the best source since there are NO connections to get wrong. Or use built-in speaker test tones.
Find the manual and carefully evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Posted on Mar 14, 2011
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Apr 21, 2014 | Harmon Kardon Harman Kardon Avr-20 Ii...
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
My 27" Sanyo DS27800 when
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
Jan 27, 2011 | Sanyo DS27800 27" TV
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Posterized!
Try 2 different signal sources, such as cable and DVD or Dish and DVD or Cable and vcr. If the same problem exists on both sources then the TV needs a circuit board.
I would like a discription of "posterized" to help you more.
Steve
Mar 24, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
154 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
