Question about Kenwood Kdc-bt645u Car CD/ MP3 Player
There is no sound at all what do we do, is the wiring bad or is the system faulty?
    Problem Solver:
  • 10 Answers
I would say if its all wired up right then the radio is at fault.
Posted on Mar 16, 2011
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
At idle sounds like bike loading up
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Good luck
Jan 27, 2014 | 2000 Harley Davidson FXDL Dyna Low Rider
Camper 12 volt system will not recharge.12 volt lights make low voltage alarm sound
most likely cause other than faulty wiring or bad ground is a faulty inverter. the specs should be taped to a panel near the unit or folded up nearby depending on the tech that installed the unit. use a voltmeter to confirm proper operating thresholds (if no spec sheet is present you can get one but contacting the manufactuer and providing a model number)
Oct 15, 2013 | Cars & Trucks
1994 HD 883 runs at idle but when your riding it surges then dies... But when it sits in idle sounds great and starts right up
Good luck
Aug 05, 2013 | 2000 Harley Davidson XL 1200 S Sportster...
Running rough, backfire, hissing sound
Hi Anonymous, be sure to check your intake seals, and the usual suspects are:
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor or intake seals.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Oct 15, 2012 | Harley Davidson FLSTC - FLSTCI Heritage...
1993 hd sportster. It runs and idles fine but when you drive 10anywhere or 15 miles it begins making a popping sound in front cylinder.
Hi Jctate55, and the usual suspects are:
Harley Davidson Wiring Diagrams and Schematics
Apr 18, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
The check charging system comes on with a red battery
SOUND LIKE FAULTY ALTERNATOR. CHECK ALTERNATOR VOLTAGE OUTPUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR IS FAULTY. CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR LOOSE CONNECTIONS OR DAMAGED WIRES,CHECK ALTERNATOR FUSE AND MAKE SURE DRIVE BELT NOT SLIPPING DUE TO BAD BELT TENSIONER. TURN OFF RADIO FIRST BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
Aug 06, 2011 | 2005 Mercury Montego
Not getting spark
need more info (need to know what type of ignition system your vehicle has: (1) traditional ignition coil /distributor system, or (2) electronic ignition, but lack of spark problems are usually a faulty coil
on traditional vehicles, and on the newer electronic ignition cars, total lack of spark would be
a faulty ECM (electronic control module) - partial lack of spark (diagnosed with a HEI (high energy ignition) spark tester kit), would be caused by a faulty coil pack (in the waste spark system), where
there's 1 coil pack for every 2 spark plugs.
I bought my HEI igntion testere kit for $20, but Harbor Freight sells a similar unit for $10.
Hope this helps.
Dec 27, 2010 | Ford F-250 Cars & Trucks
What cause sparkplugs not to fire
A
  1. Faulty coil/coil pack
  2. Faulty or corroded wiring
  3. Faulty spark plugs
  4. Faulty ECU
  5. No fuel in combustion chamber
  6. Faulty security system2_bing.gif, cutting ignition during operation.
Apr 30, 2010 | 1997 Dodge Intrepid
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
Kenwood Kdc-bt645u Car CD/ MP3 Player Logo
43 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
