Mitsubishi 50" diamond series model 50801 Screen goes black while watching tv , then maybe hours later it will pop back on and be fine for a week or so then again? Please help at what the. Problem is?that happens on all channels and I have direct tv as well as it's connected through S-video line through my receiver!!
    New Friend:
  • 50 Answers
There might be lose connection and must be reheat in the video or chroma IC...
Posted on Aug 01, 2008
Newly replaced lamp blew under 1 minute!
when you replaced the lamp were you wearing gloves,I hope so if not that could pop it.Other then that most likley a faultly bulb.
Dec 27, 2012 | Televison & Video
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
VS 50801 service mode access code (the correct one)!
Turn the tv off then enter menu 2359 power see if this works.
Oct 23, 2009 | Mitsubishi VS-50801 50 in. Rear Projection...
Tv screen goes black
VS 50801 and VS 60801 mitsubishi models (I have one each) have both had this problem develop after about 10 years of service. The picture simply started "Blinking" off after collapsing to a horizontal line - audio was still present. A simple fix to this problem is to space the yoke connector (7-pin white "Molex-type") away from the neck of the CRT (~1/8 ") . I used a plastic insulator. My 60" set had a problem with the center CRT (green) connector and thye 50" set had the same problem on the connector on the Left (red) yoke connector. The TV senses an open yoke circuit and shuts down all deflection drive. I only want a few more years of service from these sets, otherwise I would resolder the connector on the PCB for a correct and permanent solution.
Oct 23, 2009 | Televison & Video
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Screen went dark
can you confirm make and model number please.
Dec 10, 2007 | Mitsubishi WS-55807 TV
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
