Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
I need to change the small belt - Hoover U5753-900 WindTunnel Bagless Upright Vacuum
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Just remove the cover on the bottom of the vacuum by loosening the screws holding it on. Once they are off, you'll be able to slide out the rotating brush, and you'll see the belt there. Look inside the vacuum also, as when they break, they can spring anywhere in the machine. Usually they will come out when you remove the brush. Once you have the brush out, just slide the new belt over it and replace the brush from where it came. Then return the cover you first took off. All set and ready to start cleaning again !!
If you need to buy a replacement belt, take the model number from your machine to the store or contact the manufacturer online or by phone. It should only cost you about $5. for the belt.
I have the same model number and I had no problem.
Good Luck and I hope this helps.
Posted on Mar 14, 2011
Belt
Un plug unit, turn unit over,remove screws on panel covering the belt. ,first start belt on large pulley and then start it on small pulley turn brush by hand to wind the belt on. Google the model number or go to Wal-M and look in their "bags and Belt" book located next to the Vacuum cleaners.
Apr 19, 2014 | Eureka Whirlwind LiteSpeed 5843 Upright...
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
I need to know how to change the belt on a fantom xt
Turn it upside down.On the bottom where the brush is are 4 screws.Unscrew those 4 screws.Remove the plate.Now you can see the belt.There may be a second plate covering part of the belt,if so remove it too.The belt fits around the brush in a groove the same width as the belt.The other end of the belt fits on a small wheel about half way back from the brush.Put the plate back on and you are done.
May 14, 2011 | Vacuums
How do I change the belt? Do I have to twist the belt.
You do not have to "twist" the belt.
You should be able to find your answer at this URL:
http://www.bissell.com/product_search.aspx?searchType=main&searchtext=3522
Look at the users guide for information on changing the belt. I would suggest that while you are changing the belt, also take time to clean the beater brush, you have to remove it anyway to change the belt. Clean the brush as best you can and add some WD40 to both ends between the brush and the small plastic pieces that hold it in place with the vacuum.
Oct 08, 2010 | Bissell 3522 PowerForce Bagged Upright...
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 16, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Not suctioning/
i would change the belt and filter.( belts need to be changed on average every 6 months). now if you smell a burn like an electrical smell the motor is gone.
Jul 19, 2009 | Dirt Devil Featherlite Bagless Vacuum...
How do I change the belt on a 2991AVZ bagless vacuum
release the handle on the vacuum until it rests flat, then look at the part of the machine that has the hieght adjustment knob on it, that is the hood of the vacuum. there are usually three screws that hold it on. There should be a screw on the left and the right of the knob (towards the sides) and then the third is near where the small hose sticks out of the hood. once those are out the hood lifts up you will need to pull up on the brush roller ( you might need to use a small flat head screwdriver to pry it out, place it between the end of the brush and the housing and pull ) then take the new belt and place it over the small metal shaft that sticks out from the motor then put the belt on the roller and pull it into place dropping the roller back to where it was. also try turning the roller by hand to make sure you didnt pinch the belt under the roller.
Sep 17, 2008 | Eureka Vacuums
Changing the belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83009&thid=695737
Changing the belt
Posted by cbgolba on Jun 22, 2008
My husband changed the belt on our vacuum, now the metal frame doesn't fit back on the bottom. Also, there is a small metal clip that we don't know where it belongs.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should check on the owner’s manual to see how it goes together or call the Simplicity customer service line listed below to see what goes where. It’s been awhile since I have worked on a simplicity vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://simplicityvacuums.com/ Customer Service 1-888-9-Simply
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 22, 2008 | Simplicity 7850 Premier Bagged Canister...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
22 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
