Hi All, Brivis ME 20 - every two years or so heater keeps coming up with error 30 HI. Call techy out, updates something and all good for two years or so - can you spot the pattern???
  • peterp33 May 22, 2011
    Thanks for that. why does it need to be replaced/looked at every two years? 1) Are there preventative measures to take 2)Is there any way I can fix this myself. I'm a property maintenance guy and I don't mind getting in there - it seems that a techy comes out, puts in a new part - spins a little tech talk that it's the latest version installed etc only to come back two years later.
    Cheers
Code 30 is the taco connected to the bottom of the fan
Posted on May 21, 2011
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Hi any idea what causes this Brivis error. err
go to the brivis web page and type in serial number and error code theywill give you a code and repair instructions.adrian,,,,
Jun 29, 2010 | Heating & Cooling
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
222 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
