Question about KNG America KNG Lionel Train Station Lamp 028791
We have a KNG America John Deere lamp that suddenly stopped working. How do you open it up?
Schematic or replacement complete circuit board for Harley Davidson heritage V lamp made by KNG America. The incandescent bulb is fused, the other running lights and orange base light are inop.
Hi, Robert the answer to this question is way above my pay grade for this situation, I would call or visit the place where the lamp was purchased.
Good luck and have a wonderful day.
Jun 03, 2017 | Harley Davidson Motorcycles
Kng america princess lamp will not work
The princess has went bye bye.
Nov 10, 2012 | Televison & Video
John Deere starting problems
check to see if you loose spark when this happens the coil could be failing
May 10, 2012 | John Deere Garden
Does kng america have a 1 yr warranty for this lamp?
This is the problem with cheap lamps--Generic they are called--the lamp itself may have melted some plastic in the set--set needs to be opened and examined for damage---most OEM lamps come with 1 year warranty--get what you pay for......
Is this by any wild chance a Sony set?
Apr 29, 2012 | Televison & Video
Can I turn the lamp on fron a switched recpt or do I always have to push the button on the lamp?
I think you still have to push the button even if the power switch is on just to kinda get everything started, It will turn on the light & any neat movement &/or sound effects that it makes will happen & if it's anything like my daughters lamp that's similar to this, if you push the button a second time, music and sound will happen again but then the light will shut off. I'm not positive that i'm correct & apologize if i'm wrong but my daughter has a Disney dancing princess lamp & thats how it worked. It also had a switch to turn on or shut off the sound so i hope I helped somehow now that i've written a novel that should have been 1 or 2 sentences. Sorry
Jul 03, 2011 | KNG America KNG Disney Fairy's Animated...
My John Deere 4010j traveling sprinkler which is about one year old all of a sudden stopped travelling. What might be the problem? John H. Pensacola, FL
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 09, 2011 | John Deere Gilmour Traveling Sprinkler -...
I HAVE A KNG AMERICA HERITAGE SOFTTAIL LAMP THAT HAS A NIGHT LIGHT AND MAKES ENGINE SOUNDS THE BULB BLEW OUT AND NOW THE LAMP WONT WORK AT ALL NOTHING
Hi Cruzn2006, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Jun 16, 2010 | 2003 Harley Davidson FLSTC Heritage...
KNG America Harley Davidson Motorcycle Lamp Repair.
Big tip 'o' the hat to harleyds96 for giving me the impetus to get after it and tear the lamp down and sort it out. You'll need a precision Phillips #1 screw driver to remove the 8 screws. You'll have to pry the 4 little rubber pads off that double as screw hiders
Once you've carefully separated the bottom plate from the rest of the pedestal, you'll see that you need an extra set of hands to hold the plate, amber glow ring, and the main lamp body with, while you fight with the little fuse box in the center of the lamp.
They all have to be held, because the speaker wire runs through the amber ring to the bottom pad, and can't be unplugged, 'cuz it's soldered. No spade connectors, nah, that'd be too easy - and complicated. They'd like to make it so much easier to toss out another $80 for a replacement, 'cuz you stupidly lost the receipt!
So now that you've got everything separated, you discover that there's another two screws holding the ends of the fuse box to the main body of the lamp. Yes, they must be taken out too, so's you can properly fight with the four little clasps holding the fuse box together!
If you can get it popped open without ripping wires from their solder connection, you're a neurosurgeon! I lucked out, 'cuz I did the operation whilst sitting at the computer desk, so the bottom two pieces could rest on it, without ripping the speaker wires off of the speaker, while at the same time, the main body of the lamp was resting in my lap.
Now that you've succeeded in getting the box open, you'll see that you have that little fuse there, that the Harley lady mentioned above found. It's stamped - 1A/250 V, which, I suppose, would mean it could be plugged in down undah, where they use 240 volts.
So I'm going to see if I can find a 2A/250V fuse somewhere, and if that's too hot for it - TOUGH! I'll have a Harley Davidson plastic patty melt! vonster.vaughn
Jun 14, 2010 | Harley Davidson KNG America 026711...
KNG America KNG Lionel Train Station Lamp  028791 Logo
69 people viewed this question
Top KNG America Toys Experts
ray gallant
Are you a KNG America Toy Expert? Answer questions, earn points and help others
