Question about ASUS DRW 24B1ST Disk drive DVD RW ( R DL) DVDRAM 24x24x12x Serial ATA internal 525" Burner
Installed DVD BRN ASUS/DRW-24B1ST. Says there is a Code 19 problem--something about in the registry--doesn't work. Same situation before installing this new hardware.
  • cptkaplan Mar 14, 2011
    What OS, Make & Model of computer?
  • ASUS Master
  • 27,725 Answers
Click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps don
Posted on Mar 14, 2011
  • Alicia Potochniak
    Alicia Potochniak Mar 12, 2014
    Thank you, Brian! Your instructions were spot on.
  • Brian Sullivan
    Brian Sullivan Mar 12, 2014
    Thanks for getting back with the good news hope its all good now.
Sata adapter
Please check the Sata cable and the power cable
Jan 24, 2014 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
How to install a ASUS burner
In a PC, simply open a drive space on the computer, insert the drive by sliding it into the slot and screw it in place. On the rear of the burner are two connections. One is for the Power attachment and the smaller one is attached to motherboard.
That's it.
Oct 29, 2013 | OEM Systems Asus Drw-24b1st Dvd / Cd...
File corrupted or missing ccode 39
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? ! or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in
this should activate found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 15, 2012 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19).
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Nov 03, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
When trying to install driver get error " DVD Asus
I found Asus driver in the site portal.I also guess that if your PC is an OEM and you just replace the DVD.Also is a good idea to update the firmware.Here is the LINK.(http://support.asus.com/download/download.aspx?SLanguage=en-us).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 27, 2010 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
ASUS Driver wont operate
Here's a solution to fix this:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT
and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Thanks for using Fixya.
Jul 27, 2010 | ASUS DRW-2014L1 DVD±R Dual Layer Burner
Will run cd but not dvd asus DRW-24B1ST
its lens need to be replaced
Nov 09, 2009 | Cell Phones
ASUS DRW 24B1ST  Disk drive  DVD RW ( R DL)  DVDRAM  24x24x12x  Serial ATA  internal  525"  Burner Logo
1,019 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
