Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 8GB KINGSTON STICK PEN USB says write protected and i can't use it??? No setting on properties and no switch on device????
  • Anonymous Sep 19, 2008
    i have the same problem on a 8gb kingston and also a SD ram
    plz if anyone knows what to do plz post it here
    regards
Not detected
Posted on Aug 07, 2008
    Sergeant:
    Champion:
  • 246 Answers
Try to right click the pen and select properties and check out the check box in the write protected
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Fix my pen drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
Jul 11, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My pen drive is not formated due to write protection
There is either a switch or a slider on the unit.
Set the switch/slider to "write-protect-off" to enable files to be written to the pen-drive.
Oct 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
Sep 30, 2009 | Electronics - Others
How to i remove write protection on my 8Gb USB pen Drive
you just need to slide the button usually on the side of the USB to unlock. It will unlock the USB to write mode.
Jun 20, 2009 | Kingston Technologies 512MB DataTraveler I...
HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
290 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
