Question about Kenwood Audio Players & Recorders
Hi Model M505USB Broken drive belt for CD Tray opening mechanism Where can I buy a new belt Genuine part not available apparently Thanks
  • 336 Answers
Door won't open of Technics SL-CH900
Hi Robert,
probably the cd tray belt (a tiny black rubber belt that connect the tray rack with motor gear) is broken, check this by opening the player, if torn you need to buy a new spare and replace it.
May 30, 2016 | Technics Audio Players & Recorders
Isymphony m1 CD tray won't open
The CD door drive belt has broken. The same has just happened to my iSymphony. I'm now trying to source a new belt
Dec 25, 2012 | iSymphony M1 Shelf System
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
CD tray is not moving in and out easily. Grinding
unplug the unit and open it. the tray is usually controlled by a belt driven by a motor. look and see if the belt is broken. Hopefully yours is not driven by gears.
Oct 24, 2009 | Yamaha CDC-665 CD Player
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Everytime I try to open the disc tray it flashes either EX-Change or mechanical error and won't open
I have a Sony MHC-GX555 stereo and every time I try to open the disc tray it either flashes EX-Change or mechanical error and it won't open.
May 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Cd tray eject problem
THE DRAVE is DAMAGED
the carriage unit (tray) is braoken, you can open it up and use plastic weld to fix the broken off part or you can change the tray or buy a new one :)
Dec 22, 2007 | Samsung (DSSMBK482448) CD-RW Burner
CD tray opens only when there's a CD in it
Hi nolights
The disc clamp usually has a magnet in it so I would sugest the loading belt is slipping and therefore the motor can't overcome the clamp force.
A new belt should cure the problem
John w
Dec 21, 2007 | Audio Players & Recorders
43 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
