Question about Pioneer DEH-P690UB CD Player
PIONEER AVH-P4000DVD 6.1" LCD 2-DIN CD/MP3/DVD IPOD NEW
I bought this radio from USA, installed it in car, and the radio can receive only odd frequencies.So i cant listen to radio stations located on even frequencies.
anyone can help?
  • 2 more comments
  • andkws1978 Aug 05, 2008
    i am from Greece
  • andkws1978 Aug 06, 2008
    i have problem with the FM band.Here the range is 87.5 until 108.The problem for me isn't the range but that i can't have the even frequencies for example 90.2 or 90.4 or 102.8 etc...
  • andkws1978 Aug 15, 2008
    thaurfen the antenna doesn't have to do with the step of the frequencies.
  • andkws1978 Aug 22, 2008
    Anyone else to give a solution?
    Master:
  • 521 Answers
Attach a small alluminium plate to the antenna and see if it catches the proper frequencies. if it catches then the antenna is proper.if does not catch and there is same problem , then you have to replace the antenna.the alluminium plate should be not in flat position it should be in curved position.
Posted on Aug 14, 2008
    Master:
  • 623 Answers
Install new antenae
    Master:
  • 555 Answers
Where are you located, if not the United States?
Posted on Aug 05, 2008
  • Matt Jurach
    Matt Jurach Aug 06, 2008
    In the U.S. this is the normal frequency range for AM and FM radio:
    FM - 87.9-107.9
    AM - 530-1710
    Which band are you having trouble with?
How to change the dvd region code on Pioneer AVH-X2600BT - Double Din CD/DVD Car Stereo with 6.1"
This is not an adjustable device. You cannot change regions. It is manufactured for one location only.
Aug 10, 2014 | Pioneer Car Audio & Video
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I have a pioneer AVH-P4000dvd 2 din in dash dvd player. I hooked it up right, I did not do the by-pass, I hooked it up to the e-brake. When I play a dvd I get audio but no video. I have full control of the...
push in the driving brake. while holding in the brake , engage the parking brake. disengage the parking brake.then repeat this step again. a notice should pop up and you should be fine after that. I put one in a F-350 and had the same problem.
Jun 27, 2009 | Pioneer AVH-P4000DVD Monitor
How do i get to the menu?
From the main menu (where you choose RADIO, DVD, USB), look below at the smaller buttons. One of those is AUX.
If you have the right hook-up (Pioneer CD-i200), then you should be able to use the IPOD option instead of the AUX.
This can be found at http://www.sonicelectronix.com/item_8599_Pioneer+CD-i200.html for $19.00
May 09, 2009 | Pioneer AVH-P4000DVD Monitor
No video from ipod
Do you have the green cord that attaches to the parking break hooked up?
This stereo is designed so that you cannot watch videos while driving, therefore you need to have the parking break on in order to get video.
when you play a dvd with out the parking break on, you will only get sound.
Mar 18, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod problems on my pioneer avh
To be working the ipod need to be hook up with the cable cd-1200 (not sold with the avh)and to be plug to the ipod plug on the back of the radio..if you plug the ipod on the usb it wont do..the cable is around 30 $ ..it is the good way to play your ipod ..but if you have a ipod touch 2 generation like i have it wont charge ..if you have any other ipod it will be charging when in use..
Mar 04, 2009 | Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
CHANGE REGION 1 TO 2 FOR AVH-P4000DVD
Kali Mera, Ti Kanis?
I have been looking in to this, but there does not seem to be a hack available.
http://www.videohelp.com/dvdhacks?dvdplayer=AVH-P4000DVD&hits=50
Signomi
Oct 24, 2008 | Pioneer AVH-P4000DVD Monitor
Pioneer DEH-P690UB CD Player Logo
194 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
