Question about Kenmore 22422 Top Load Washer
Washer My washer will not spin the water is still in my washer say ld
If the machine still comes on but doesn't spin, you probably need to replace the coupling. More than likely coupling has cracked or the rubber band that holds it together has worn and broken. Happened to mine twice. The part is only about $10 if you can manage to do it yourself. Part # 285753A. I'm a woman and was able to do it (if that helps any). Good luck.
Posted on Aug 01, 2008
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Showing ld code and wont drain or spin
Hello the LD code simply means "Long Drain"
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping.
Thanks
May 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
